Engine dies intermittently
Old 09-17-2009, 10:28 PM
  #16
MarcR94v6's Avatar
Also check all wires around the coil to make sure they are not kinked. I've replaced a few coils and one time a few wires got kinked and I didn't even notice until a shop pointed it out and fixed it for me for a similar problem I had, only with less codes thrown.
MarcR94v6 is offline
Old 09-18-2009, 06:40 AM
  #17
berakahs's Avatar
really? where would they be kinked?
berakahs is offline
Old 09-18-2009, 06:56 AM
  #18
Originally Posted by 94Sleeper
I can send you a picture of the failed unit when its out but if the replacement Opti fixes the problem I will not be opening it up, I will be throwing it out.
I just found out the replacement Ignition harness price went from around $60 when I bought on a couple of years ago to about $180 today. Great.
You can get opti harnesses from eficonnection or lsxtune for less than $40.
The original problem sounds like it could be the ignition switch or connection down there.
shoebox is online now
Old 09-18-2009, 04:23 PM
  #19
94Sleeper's Avatar
I thought about that and I tried moving my harnessing around under the dash and under the hood. I also tapped on the steering collumn and ignition switch with a screwdriver as well as the relay box and ECU without being able to get the described reset condition to reproduce. I thought if it was an intermittent connection I should have found it by now.
94Sleeper is offline
Old 09-18-2009, 04:46 PM
  #20
Do you know where the ignition switch is (on the column, under the dash)? Did you wiggle the connector to it? If all your ignition switched circuits go dead when this is happening, it is a good bet it is the switch or connection.
Old 09-18-2009, 07:49 PM
  #21
94Sleeper's Avatar
I don't think I tried that particular connector. I do have the Helms Manual so I will find the ignition switch and give a bit of a shake to see if that's where the problem is.
Old 09-18-2009, 09:55 PM
  #22
http://shbox.com/ignsw/ign_switch_repl.html
Old 09-20-2009, 01:43 PM
  #23
94Sleeper's Avatar
I dropped the lower dash panels this morning and found the Ignition Switch and was able to check it out. With the ignition on (engine not running) I was not able to reproduce the reset problem while wiggling the connector. I manipulated the connector for a few minutes with no luck.
I had checked the coil harness initially as I have had issues with it in the past. I replaced the coil pigtail a couple of years ago when I found it was frayed.
Originally Posted by matLT1
I've had these same conditions twice before, and each time it was the optispark.
I have never had an Opti do this to me before it had always just died in the past, but I know they can be a fickle beast. I guess I will be changing the Opti and see what happens.
Old 10-03-2009, 11:11 AM
  #24
94Sleeper's Avatar
Thought I would update this thread and close the loop so it may be useful to someone in the future.
I replaced the Opti and the car runs great. I've out a few hundred miles on the new Opti without a problem. Took it to the track last Saturday and made 8 runs and won the club bracket with it.
Thanks for all the input
Old 10-03-2009, 06:27 PM
  #25
EFIConnection has a good price on an Opti harness.
Injuneer is offline
Alex Barnes
01-24-2015 10:21 PM
Oncomingstorm22
01-22-2015 07:15 PM
A's 91 Z28
01-11-2015 10:58 AM
Injuneer
12-15-2014 09:36 AM
Ricardo
11-29-2014 10:58 AM
Quick Reply: Engine dies intermittently
