Engine is being pulled. Anyone help with a cam?
Old May 21, 2004 | 11:12 AM
SplitFire's Avatar
My engine is being pulled because I have oil leaks coming from almost everywhere. Since it will be out, I'd like to get a new cam, but know nothing about them. I am looking at the Comp Cams 305 or the 224/230. Will tuning be required for either of these?
What all should be bought along with the cam to make sure everything runs right? The guy at the shop suggested a new timing chain. Anything else?
Old May 21, 2004 | 11:23 AM
viperkiller's Avatar
i have the xe 230 236 112 it works pretty good and makes deasent power, and sounds awsome. with 3:73 and the a4 it runs smooth at 65. the cam surge levels around 22-2500 rpm.
Old May 21, 2004 | 11:43 AM
Gripenfelter's Avatar
I have an XE 230/236 for sale.
$175 u.s.
Old May 21, 2004 | 01:28 PM
Revolutionary's Avatar
For a daily driver I would stick with the 224/230
Old May 21, 2004 | 01:34 PM
SplitFire's Avatar
Will the 224/230 work fine without tuning and 1.6 rockers? Would a new timing chain really be needed?
Old May 21, 2004 | 01:41 PM
Brandon94Z28's Avatar
After any cam you would be crazy not to tune the thing to run at its best. I have the 227/233 and it definately needed a good tune. Madwolf did mine for inder 100 bucks and it ran much better. A timing chain will only be like 20 bucks and is needed. Don't skimp or you will pay dearly later.
Brandon
rideordie
Nov 5, 2019 04:52 PM
oldschool
Feb 9, 2016 09:21 PM
Injuneer
Dec 15, 2014 09:36 AM
Noenav
Dec 6, 2014 07:35 PM
