engine bay cleaning
Old Apr 26, 2006 | 12:05 PM
robwin95z's Avatar
engine bay cleaning
not so much concerned about the engine but my fender wells inside the engine bay are gross. alot of grease and grime. what's the best solution to clean it up without hosing it down for fear of the opti? what chemicals can clean it up without messing the paint up? anyone got an tricks they used?
Old Apr 26, 2006 | 12:08 PM
Rising Phoenix's Avatar
Re: engine bay cleaning
Use Foaming Automotive Simple Green. They have it places like Autozone, Pepboys, etc. All you have to do it get those areas soaked really well with it, let it sit for 15 minutes, and scrub away with a rag or something.
Old Apr 26, 2006 | 12:20 PM
robwin95z's Avatar
thanks man, i'll give that a try this weekend.
Old Apr 27, 2006 | 09:08 AM
cjmatt's Avatar
aww just wash it with a hose. ive sprayed my car off tons of times and ive even got the unvented opti. just dont spray the radiator shroud or top or front of the engine. i always wipe it down afterwards and let it airdry an hour or so before driving.
Old Apr 27, 2006 | 10:41 AM
MeanGreen97Z's Avatar
Famous last words.....
Old Apr 27, 2006 | 10:56 AM
thesoundandthefury's Avatar
I use this stuff called Engine Brite. Works wonders. It comes out in a thin stream so it's easy to aim it where you want it without getting too much overspray on your electronics. After three saturations with the stuff, 90% of the dirt and grime in my engine bay had literally just dripped to the ground. All that was left was stuff down in nooks and crannies which wiped up easily enough. The best part is that this stuff was formulated to look sort've like Armor All: left the whole engine bay with a shiny "wet" look. Highly recommended.
Old Apr 27, 2006 | 02:22 PM
matt65's Avatar
Watch The Opti!
Jazsun
Dec 29, 2014 12:14 PM
formula218
Dec 2, 2014 04:27 PM
kandied91z
Aug 4, 2002 02:53 AM
Caps94ZODG
22
Jul 30, 2002 08:45 AM
