emissions
Old Oct 24, 2009 | 06:11 AM
graycamaro12288's Avatar
emissions
is there a way to get rid of 02 sensors and cats but not affecting any performance on my camaro.if there is what should i do. i have heard about straight pipes but i think the computer will pick someting up an will not run good.
Old Oct 24, 2009 | 07:21 AM
jperran's Avatar
Deleting the cats won't effect the PCM, but it will throw a code. You need to have the rear o2 sensors deleted from the tune. These sensors just say hey the cats aren't working, the pcm doesn't use them to figure out fuel/spark or anything like that.
Old Oct 24, 2009 | 11:18 PM
Venomous360's Avatar
As long as you dont mind your check engine light being on ALL THE TIME like mine is then just remove the cats, I still have my 02s plugged into my LTs.
Old Oct 25, 2009 | 10:28 AM
No one can accurately answer your quesion without knowing the year of your car (which determines whether it is OBD-I or OBD-II, how many cats it has, and how many O2 sensors it has). You also have to tell us if you are asking about the pre-cat or the after-cat O2 sensors, or possibly all of them.
You need to add a "signature" with basic info about your car, including year, model, engine, tranny and any major mods. That helps people provide you with accurate answers.
Old Oct 25, 2009 | 11:29 AM
Whats the difference between OBD 1 and 2?? does one make a difference with no cats and one doesnt??
Old Oct 25, 2009 | 11:35 AM
grumpygreaseape's Avatar
in regards to the use of 02 sensors, obd 2 uses additional sensors placed after the catalytic converters to determine the efficiency of the cats. it is something that can be tuned out of the pcm, if you like.
Old Oct 25, 2009 | 03:58 PM
Exactly.
93-95 OBD-I has only one cat. Has no after-cat O2 sensors, and no OBD diagnostic for cat performance (one exception is the 95 CA emissions A4's, which have dual cats, but are still OBD-I and no after-cat sensors). 96/97 OBD-II has dual cats, running in parallel, and a sensor after each cat to monitor activity, and an OBD diagnistic routine to determine the O2 storage level of the cats.
Many questions regarding the LT1's are difficult to answer without knowing the year of the car. There are numerous, significant differences from year-to-year.
Old Nov 3, 2009 | 01:38 AM
my bad i got a 95 camaro z28 with two cats two o2's. its a V8 5.7L with a 4 speed automatic trans. OBD 1 with OBD 2 plug. with no mods.
Old Nov 3, 2009 | 05:25 AM
Then it would be a "CA Emissions" car. Check the build code tag for RPO "YF5".
sleeperZ96BT
Sep 9, 2015 08:28 AM
sherwinZ28
11
Aug 15, 2015 05:38 PM
FredM
Exhaust System
Feb 18, 2015 05:37 AM
jgeorger
Oct 24, 2002 09:31 PM
jgeorger
New England Area
15
Sep 8, 2002 09:50 AM
