Emission Cheating Guru's HELP!
Old Feb 24, 2004 | 11:16 AM
aintno6's Avatar
In my part of Illinois we are required to take our cars for emission testing. My 97 Formula, is OBD-II car. So when I took it last year, all they did was hook it up to pcm connector, and check my gas cap. And that was it, very quick and simple, no sniffer on the dyno. So here comes the questions.
I just ordered my Jet-Hot's with out the air and egr fittings, because jet hot is on back order on th ones with the air and egr. So is there a way to cheat the pcm, so I can still pass emissions. Because Im going to have speed inc install them, I was wondering if they would know or not. Just wondering.
Good thing I dont have to be tested for an other year or so.
Old Feb 24, 2004 | 12:07 PM
Zachz28's Avatar
They should be able to program the emissions fittings out of your computer and then you will still pass
Old Feb 24, 2004 | 12:11 PM
Brundle's Avatar
Don't know anyone that can get you a fake emissions test certificate??
I know several guys with 3rg gen f-bodies, that arent emissions legal and do this. Our e-testing here is 30 bucks, it only costs them another 30 to get a fake one.
Old Feb 24, 2004 | 12:14 PM
aintno6's Avatar
sweet this is good news to hear lol.
Old Feb 24, 2004 | 12:16 PM
BUBBA's Avatar
I don't know about "emissions fittings", but I do know that they need certain readings from your PCM and if they don't get them, you don't pass. JMHO
Ed Wright deleted certain readouts from my PCM when he programed it. I had to reinstall my stocker to pass.
We may be talking apples and .....here.
Old Feb 24, 2004 | 12:20 PM
93transam1234's Avatar
I have JETHOT LT and i passed emis. The company that installed them also programed out the emis. stuff in the PCM, If they didnt i would get an SES light.
Try asking in the programming section
But it worked for me!
Old Feb 24, 2004 | 12:42 PM
Zachz28's Avatar
I know a guy that has a 99 SS here in IL and he has nothing not EGR, AIR, even no Cat all you need to to is program AIR and EGR in your comptuer and the the emissions plug into you Computer and i thinks ever things ok and your on your way ubt it only works with OBD 2 (96+)
Old Feb 24, 2004 | 01:42 PM
aintno6's Avatar
thanks for the help guys. hopefully I wont be charged an arm and a leg for the removal of the air and the egr. Cant wait till they come in the mail. I heard people notice a big difference after doing long tubes.
Old Feb 24, 2004 | 02:26 PM
19formula94's Avatar
Just an idea, but i'm going to school out in phoenix, so i cant get my car back to ohio for testing so i get a waiver to fill out saying i'm at school. I dont know how much checking they do to find out if you're really in school somewhere, but maybe you can take that route. I also got the Jet-Hots with emission hook-ups just incase i need them in the future
Old Feb 24, 2004 | 03:07 PM
neil350's Avatar
It should fail if its missing air/egr and been programmed out because it will say not ready when they go and check it. 96-6speed has LTs on his Z28 and it cant pass in Harris county because its missing the air/egr stuff.
In Texas if you live in a county 9 months out of the year you can have it inspected in the country your in.
Old Feb 24, 2004 | 05:45 PM
aintno6's Avatar
i guess, ill have to find out, when I take it into the shop.
Old Feb 24, 2004 | 07:22 PM
rene95z28's Avatar
be careful with fake stickers, I am in harris county and it is a class B misdeamenor if you get caught.
Old Feb 24, 2004 | 08:45 PM
Steve in Seattle's Avatar
find out what they do if the OBDII port isn't "easily accessible" or they "can not communicate" with the PCM.
Most states have a clause that if the OBDII port is unavailable (say it's behind a big speaker box), or the computer won't connect (perhaps you spliced in weatherpack connectors to the OBDII harness and forgot to plug them in ) that you're allowed to run a sniffer test like pre-emmissions vehicles.
To pass a sniffer:
- use a stock thermostate
- deactive the electric fans (pull fuse, reprogram, or jsut unplug them)
- run a gallon of short-carbon-chain alcohol in the tank. Look for denatured alcohols at drug stores (ethanol or iso-propanol... just try to get a high alcohol % mixture, as the remaning % is usually water). DO NOT do this OR fill the tank the same day as the sniffer. Testing on a full tank, or sloshing the fuel around with hard cornering is a great way to fill your carbon canister with fuel (bad for HC levels when testing).
- get the car up to 60mph and cruise at low rpms for about 5 to 10 minutes on the highway... this will help empty the carcoal canister which is a common sourse of HC spikes.
- drive the last few blocks in the lowest gear you have and get the RPMS's around 3000 to keep it hot (without red-lining your engine).
- do NOT shut off the car while waiting in line, and try to test at low-demand times (like the middle of the month, and outside the lunch-hour rush).
If you have access to editing software:
- raise the fan turn on-temps
- raise the idle speed to ~100 below the state's max idle speed (WA uses a 1100 rpm max for testing... we try to set idles at 1000 to keep the engines hot and piston speeds up for more effieciency). Any test station can tell you what the max idle rpm is that they'll test.
If HC level are still ugly, you can try this... but note that this is a sniffer ONLY tune, and you should NOT go WOT with it:
- advance the timing 5 to 8 degrees beyond stock
- set the red-line around 3000 rpms (to prevent hitting peak VE and possible detonation)
- use unleaded race gas (104 octane) to help prevent detonation.
If NOx levels are too high, try retarding the timing a few degrees to cool the combustion chamber. You will be giving up a few points in the HC situation, but usually its one or the other that will fail you. If its both you have some serious problems.
Old Feb 25, 2004 | 01:52 AM
aintno6's Avatar
cool thanks. I would hope I wouldnt have to put it under the sniffer. But If I had to, I would use your info. Plus I had a few idea's of my own too. But like I said hopefully they can just cheat the computer. Good thing I got an other year or two to go.
But it seems like the Illinois guys who posted here, know of OBD-II guys, who got around it. So I'm sure if they did, I can. Thanks Again.
Mike
sleeperZ96BT
Sep 9, 2015 08:28 AM
sherwinZ28
11
Aug 15, 2015 05:38 PM
Magenta_Hearts
Mar 25, 2015 10:24 AM
FredM
Exhaust System
Feb 18, 2015 05:37 AM
jgeorger
New England Area
15
Sep 8, 2002 09:50 AM
