eletrical problem
Old Oct 20, 2004 | 06:39 PM
1badasZ's Avatar
Exclamation eletrical problem
im having some kind of electrical problem could someone please help me? my lights are all screwed up sometimes all of them are on and when i turn on my lights and fog lights only one fog light and one headlight will come on. when i turn the foglight switch off both foglights come on and just which one of the headlights that wants to. once i turn the lights and car off they stay kinda dim and eventually go out. my water pump stays on after i turn the car off and it must be turning on n off when the car is running cause it runs hot from time to time. anybody have any idea what it could be?
Old Oct 21, 2004 | 09:36 PM
1badasZ's Avatar
Re: eletrical problem
ttt
come on guys i need some help here...
Old Oct 22, 2004 | 09:12 AM
slopokrodrigez's Avatar
Can you give us a history of when the problem occured like after something was done? Can you also tell us what circuit you put the water pump on? Also a more precise description of what is happening with the lights and when would be helpful. Like when exterior lights are off, such and such happens, anywhere in the vehicle and when you turn the lights on, such and such happens and include everything happening everywhere.
We can then do the best we can to help you.
Dave
Old Oct 23, 2004 | 12:32 AM
1badasZ's Avatar
Dave
all i did was change the oil and adjust the valves. the car was fine before the head n cam swap but it had sat up for a year. but this just recently started happening. i have the water pump on a relay and its wired to the lil red box on the passenger side and the ignition fuse. the car cranks n stuff fine. when i turn the lights is when things get crazy. inside lights and stuff are ok its just the head lights and the left signal. if i just turn it on it blinks fine but when i turn the headlights on the arrow on the dash stays lit on the left side but its dim. when that is lit up it wont blink at all when you turn it on. my head and foglights do different stuff. like the left bright light will be on and the right low beam. sometimes both will be on on the right side and none on the left. but usually the ones that arent supposed to be on are really dim. only one fog light will come on if you have the headlights on. if you turn on just the park lights both will come on. sometimes when you turn the lights off all together they will stay on for a while but just barely burning(not even enough to see them unless you are directly in front of the car) but if i unhook my water pump from the lil red box they will go right out. after it ran hot i havent driven it cause i donno if the pump was turning on and off or something or if the fans werent kicking on or what the case may be
Old Oct 25, 2004 | 01:30 PM
1badasZ's Avatar
another thing i found out is that my abs relay is clicking and the traction and brake lights on the dash are flashing too. and now my windshield wipers arent ...what the hell could be going on?
Old Oct 25, 2004 | 03:45 PM
RobbyRob's Avatar
Sounds like your signal relay is bad. I would check them all.
Old Oct 25, 2004 | 03:52 PM
WS Sick's Avatar
I would check grounds for starters, you could have a loose or corroded ground wire to the body, check the one on the drivers side rad support up top for starters. Then play with your light switch , move it around slowly and see what kind of results you get.
Old Oct 25, 2004 | 06:32 PM
1badasZ's Avatar
where is it located. the right signal works and the left one everynow and then but i havent driven the car lately that much cause i dont wanna mess anything up
Old Oct 25, 2004 | 06:43 PM
1badasZ's Avatar
how many grounds do our cars have? mine is a 95 if there are anything different about any of them
Old Oct 25, 2004 | 10:09 PM
RobbyRob's Avatar
If you remove the plate under the steering colum on the right side was one. It's a round little cylinder. I think thats for the signal's . I don't remember where the one for the hazards is. The grounds you have for the battary to the body right by that red box. Clean those off and check for the frame to the motor. and under the dash when yur under looking for the signal relays.
Old Oct 28, 2004 | 12:36 AM
1badasZ's Avatar
well i finally found my problem. the ground on the radiator support was loose. the bolt hole was stripped out. i just moved it to another place and everything seems to be working fine. i hope so anyway i still havent driven the car yet i gotta put my stat back in. but thank yall for the help
Old Oct 28, 2004 | 12:40 AM
RobbyRob's Avatar
That should work...
Old Oct 28, 2004 | 09:22 AM
WS Sick's Avatar
Exact same thing happended to me on my old 93. I pulled my hair out for a week.
liamcg97
Nov 25, 2019 05:55 PM
Matt W
Apr 24, 2015 12:54 AM
AlaskaZ28
Apr 17, 2015 08:54 AM
greenzee28
Mar 26, 2015 09:13 AM
Magenta_Hearts
Mar 25, 2015 10:24 AM
