Electronic B&M shift kit just as good as a real shift kit?
Old Jul 16, 2003 | 01:09 PM
  #31
Izod's Avatar
i advise against, for reasons shoebox stated. sure the A4 tranny can handle a lot of abuse (well...hehe), but everyone i've ever known who used the B&M regretted it, esp. 15-30k down the road. Saving $70 could cost you $1500, is that worth it???
Old Jul 16, 2003 | 02:07 PM
  #32
Originally posted by chevyboy_z28
it is I , one question tho, on the link above are both of those wires 12v b/c only one is labeled?
Not sure what you mean. One is labeled + going to the LED and another is labeled - to ground for the switch.
Old Jul 16, 2003 | 02:30 PM
  #33
chevyboy_z28's Avatar
so they are both the same kinda wire (12v) just one is going to the negative (i.e. cigartte lighter) and the other to a positive source (i.e. fuse box)?
Old Jul 16, 2003 | 03:00 PM
  #34
snorkelface's Avatar
I don't suppose this mod is able to be done on '97s, is it?
Old Jul 16, 2003 | 03:09 PM
  #35
Elvis '97 Trans Am's Avatar
Do the Trans Am's have a performance feature in the tranny? Anybody know?
Old Jul 16, 2003 | 03:41 PM
  #36
You are making this way too hard.
Follow the very simple diagram. Use the black ground wire on the lighter for the ground and wire the 12v to ignition fed power at the fuse panel. (you actually can use the red wire to the lighter as the 12v, because even though that wire is powered all the time, the LED will not light unless the pcm sends a ground to it. That can only happen when the key is ON)
Not sure what you mean about "same kinda wire", but physically the wires are the same type.
Old Jul 16, 2003 | 03:46 PM
  #37
OBD-II pcms (96-97) do not have this built into them. It is only present on the 94-95s. 93s did not have it because they did not have electronically controlled transmissions.
Old Jul 16, 2003 | 09:28 PM
  #38
yea prolly b/c im a freakin idiot. i will do "under the hood" work all day but its just something about this electrical stuff that makes me feel like a preschooler in a coolege class or somethin (i just cant follow it yet )!
Old Jul 16, 2003 | 11:08 PM
  #39
Thank you Shoebox for ur help.
Old Jul 21, 2003 | 01:24 AM
  #40
Cerwin Vega Fan's Avatar
Could someone tell me what P/N 10195559 is and why the hell do I have to pay so much more just because I have a vert.
Old Jul 21, 2003 | 05:44 AM
  #41
revtime's Avatar
My 2 cents.
Put the shift kit in it and be done.
I love my Trans Go shift kit.
Old Jul 21, 2003 | 08:04 AM
  #42
You don't have to buy any GM part. Just get a momentary button and an LED-a few bucks.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
97TA-WS6-Con
Feb 1, 2015 01:01 PM
Jan 23, 2015 01:13 PM
Jul 4, 2005 05:00 PM
