Electronic B&M shift kit just as good as a real shift kit?
i advise against, for reasons shoebox stated. sure the A4 tranny can handle a lot of abuse (well...hehe), but everyone i've ever known who used the B&M regretted it, esp. 15-30k down the road. Saving $70 could cost you $1500, is that worth it???
Originally posted by chevyboy_z28
it is I
, one question tho, on the link above are both of those wires 12v b/c only one is labeled?
it is I
so they are both the same kinda wire (12v) just one is going to the negative (i.e. cigartte lighter) and the other to a positive source (i.e. fuse box)?
Follow the very simple diagram. Use the black ground wire on the lighter for the ground and wire the 12v to ignition fed power at the fuse panel. (you actually can use the red wire to the lighter as the 12v, because even though that wire is powered all the time, the LED will not light unless the pcm sends a ground to it. That can only happen when the key is ON)
Not sure what you mean about "same kinda wire", but physically the wires are the same type.
Originally posted by snorkelface
I don't suppose this mod is able to be done on '97s, is it?
Do the Trans Am's have a performance feature in the tranny? Anybody know?
Originally posted by shoebox
You are making this way too hard.
Originally posted by Cerwin Vega Fan
Could someone tell me what P/N 10195559 is and why the hell do I have to pay so much more just because I have a vert.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Jan 23, 2015 01:13 PM
Jul 4, 2005 05:00 PM
