Electrical problem, shoebox?
Old Aug 17, 2004 | 08:01 PM
Cmr0z28's Avatar
So today my driver side window decided to stop working. All of my switches are fairly new. The button to make the passenger side window go up/down works, the locks and mirrors work, just not the driver side window. When I press the button, I hear a clicking noise under the instrument panel. Any idea what would cause this? If so, how much and where do I get it?
Thanks all....
Old Aug 17, 2004 | 08:04 PM
Re: Electrical problem, shoebox?
Sounds typical of the window motor. You might want to test the motor directly by jumping power and ground to it's connector.
Old Aug 17, 2004 | 08:37 PM
Cmr0z28's Avatar
Damn, guess the door panel is coming off. I've had this happen and usually if I just hit the door panel it starts working again, but I haven't had the problem in awhile.
Old Aug 17, 2004 | 10:23 PM
Cmr0z28's Avatar
Also, shoebox, keep in mind the clicking is coming from under the dash, where the knee panel is. Let me describe the clicking...
When I press the switch, as I release it, I hear two clicks. When I release it slowly, the 2 clicks are further apart the slower I release it. Could it be the express down relay causing the problem?
Thank you for your time, patience and help
Old Aug 17, 2004 | 10:29 PM
The clicking comes from the express down module-also typical to what people hear when the motor is not working.
Old Aug 18, 2004 | 01:57 PM
Cmr0z28's Avatar
Ok, the switch tested fine, so I pulled the motor and that tested fine. Now what?
Old Aug 18, 2004 | 02:02 PM
Put it back together and see what it is doing now. Did you take the motor out and test it? It might be inclined to work if there is no load on it.
Old Aug 18, 2004 | 02:20 PM
Cmr0z28's Avatar
i plugged the motor in, hooked up the switch, put the key in and it works fine
Ah whatever, time to put it back together...yay
liamcg97
Nov 25, 2019 05:55 PM
eanhl2004
Apr 4, 2015 12:01 PM
greenzee28
Mar 26, 2015 09:13 AM
robcarnut
Mar 20, 2015 03:40 PM
97z28k&N
Jan 9, 2015 04:58 AM
