Electrical problem? HELP!
I replaced the opti, plugs, wires, and put longtubes on on my car about 3 months ago. After the install, everything ran very strong and all was well. I dont drive the car very often for fear that something else might break or go bad, it happens so often, but even that didnt help. A couple weeks ago i noticed the car while idleing at a light or something the rpms would slowly drop and keep droping until the car dies. Then on a cold start, the car would start good, idle decent, but as soon as i go into drive or reverse, it dies. Another symptom i have is after the car warms the car will die while driving and immediatly come back to life, the longer i drive it, the more this happens. I am at a loss, its always something and i am fed up with this car. It does throw a code after it dies and comes back while driving, but the code goes away until the car dies again. I had the computer scanned and the guy said that the computer was responding and the scanner was just saying that it was ready. The guy said i had a bad ground because the computer was responding and maybe that was my problem. Any suggestions?
Re: Electrical problem? HELP!
Don't guess.... get it scanned by someone who knows what he is doing.
What year is your car? That will determine what tool/method is required to read the trouble codes. Sounds like you may have a 95, and he scanned it with an OBD-II scanner.
Helpful Hint: Add a "signature" with the basic info about your car.... year, model, tranny type and any major mods. That way people will be able to respond more accurately to your tech questions.
Its a 94, OBDI, I looked at the scanner and it said for OBDI and OBDII. Ill check connections again, and tryed to have it scanned somewhere else. Is their even a problem that you can have with a car that will not allow the computer to be scanned?
eanhl2004
Apr 4, 2015 12:01 PM
