Electric cutout problem
Re: Electric cutout problem
Im not sure that the motor is burned up, because I manually closed the cutout up and it opens like a charm. everytime But it just wont close. I did alter the wiring on my device. I was short one wire so what i did was cut the adaptor off the end of it and just run black and red wire all the way from the switch to the cutout.Would this mess me up?
I acutally figured it out but I have one problem still. How I wire dit was like this I cut the adaptor off the end of the motor and exposed the red and black there then after that I ran the black and red wires into the car into console where the cig lighter goes then I ended up connecting the orange from the cig to the red wire and the black form the cig to the black wire and this makes my cutout closed if I switch the wires around and make red to black and black to red the cutout opens How do I incorperate the switch? Where does it fit in so I dont have to hotwire my cutout each time?
I have the switch that comes with that comes with the q-tec cutout its the one with an led on the tip . Push it one way it turns green the other way it turns red. One color for open close i think.
Rich_z28
Aug 29, 2002 10:44 PM
