EGR unhooked?
Old Apr 28, 2006 | 12:15 AM
neil350's Avatar
EGR unhooked?
Is it possible to leave it unhooked with out any adverse effects? Air doesnt seem like it would be an issue, just wondering about the EGR valve.
Old Apr 28, 2006 | 07:25 AM
wrd1972's Avatar
Re: EGR unhooked?
You can leave it unhooked and it wont hurt a thing, but you will probobly get the EGR fault code and the SES light.
Old Apr 28, 2006 | 07:30 AM
Re: EGR unhooked?
The EGR system controls combustion temperatures. You might get some detonation that you otherwise would not if the EGR was working. Therefore, adverse effects are possible.
Old Apr 28, 2006 | 05:48 PM
neil350's Avatar
Re: EGR unhooked?
I see thanks guys, I got a way to hook my air up on the LTs, egr not sure yet.
Old Apr 28, 2006 | 06:40 PM
Hawk's Avatar
Re: EGR unhooked?
I run no EGR and disabled knock sensor, programmed to pull 0 degrees at all times.
I always run premium and have no problem with knock. I think you will be OK with a disabled EGR, especially if you have your knock sensor circuit working.
Brian
marlar98
Oct 21, 2015 02:02 PM
sleeperZ96BT
Sep 9, 2015 08:28 AM
MDZ28
Sep 7, 2015 09:16 PM
Pwilson59
Sep 3, 2015 08:47 PM
War Engine
Aug 28, 2015 06:04 AM
