egr removal ?tion
Old Jan 25, 2004 | 03:16 PM
Myrdyn98's Avatar
egr removal ?tion
anyone know a website that has directions and the equipment needed to scrap the egr? Cause the egr crap is about the dumbest thing made. Hey lets take exhaust gas and run it throught the engine one more time yay
Old Jan 25, 2004 | 03:21 PM
AsianSensation's Avatar
The EGR system does have a purpose.
Just remove the 3 items on the left of the picture. Cap/block all ports.
http://www.97ta.com/lt4/lt501.jpg
Old Jan 25, 2004 | 04:09 PM
EGR has the side benefit of reducing the tendancy for detonation, when lugging the engine at low/mid rpm's in too high a gear. Also improves gas mileage a little, by effectively "decreasing" displacement.
Old Jan 25, 2004 | 04:13 PM
QCKZ28's Avatar
there is no need to take the EGR off, if it is functioning correctly. NO PERFORMACE GAIN. the only reason i took mine off was my headers dont have emissions fittings.
but you will need 3 blockoff plates (i made mine from sheet metal and used a dremel tool)
1. take the EGR valve off the back of the intake manifold (driver's side, its black and round)
2. take the EGR tube off the back of the intake manifold (passenger side)
3. take the EGR tubing off the passenger side exhaust manifold (a major PITA to get to on stock manifolds)
and cover all the holes with the block off plates. you can also remove the EGR selonoid (driver's side intake manifold) and plug the vacuum port
jesse
Old Jan 25, 2004 | 05:30 PM
Mystic97Z's Avatar
i've heard, that althoug the air in the exhaust is extremely hot, its still cooler than the air inside the engine,,so it actually helps. thats why i didn't remove mine.
Boss002
Jan 20, 2016 12:17 PM
Jlo
Jul 29, 2015 03:52 PM
RX Speed Works
Jul 24, 2015 02:25 PM
Dark Zeiro
Jul 19, 2015 08:25 AM
Jul 17, 2015 02:47 PM
