Educate me on Rocker Arms
Old Jan 28, 2004 | 06:16 PM
Fastbird93's Avatar
I'm wanting to check and see if I've got any too tight or not. What I'm needing to know is the most simple way to go about this. I haven't pulled the valve cover yet, but figured I would since I've already got the alternator off, and my right bank is the one with the problems.
So, any takers on clueing me in on how to check? I've just never done it before.
Old Jan 28, 2004 | 06:32 PM
12SCNDZ's Avatar
If they're too tight, the car won't RPM very well...If it'll even run.
I tried a few different methods of adjustment with mine. I finally ended up doing it with the engine running.
Easiest way...Loosten until you hear chatter...Tighten until it just goes away, and then go 1/8 turn more. Some say 1/4 turn..I went 1/8 and I don't think mine is arguing too much .
Frank
Old Jan 28, 2004 | 06:43 PM
Fastbird93's Avatar
Well, I don't think they're too tight then. The car RPM's fine, just has that fuel issue. I thought I might have a valve not opening all the way causing a rich condition. I guess not......They're whisper quiet as is. Joe did a good job there.
Thanks Frank!
Old Jan 28, 2004 | 06:58 PM
SVT Killer LV's Avatar
i really can't stand doing it dynamically....
tdc cylinder at a time 3/8 past zero lash, worked for me everytime, on every cam install i have done.
Old Jan 28, 2004 | 07:03 PM
QCKZ28's Avatar
Frank
i did it exactly like Frank
jesse
13qtr
Oct 28, 2016 08:11 PM
Quickss96
Jan 29, 2016 05:56 PM
LT14LIFE
Nov 15, 2015 06:22 PM
95chwagon
Oct 16, 2015 12:24 PM
Z Power
Sep 19, 2015 11:19 PM
