Easiest Big Block Engine Swap?
Old Sep 12, 2008 | 11:07 AM
96LT1TX's Avatar
I am wondering what is the cheapest/easiest big block drop in for an LT1 Formula. I have a 383 and am thinking about either going solid roller with some good heads (my heads now are under ported big time for a 383) or going with an engine swap. The opti crap has made me angry for years, something a little different would be nice. I carbed (I guess is cheaper?) I wouldn't mind, or if I could somehow use the stock ECM (dreaming here) that would be great. I have been working a LOT lately and not much time to work on the car. It needs new heads though bad.
Old Sep 12, 2008 | 02:33 PM
rskrause's Avatar
Moderator
A big block in a 4th gen is not easy. There have been some good threads on it - if you do a search you should find them. The cost, besides the cost of the motor, is going to be a function of how handy you are. There is a lot of minor fabrication, cutting/fitting, etc. needed. Very expensive to pay someone to do, but if you don't have the tools, equipment, time, or skills, you are stuck.
Rich
Old Sep 12, 2008 | 04:17 PM
96LT1TX's Avatar
Ya I have seen a few write ups on 400 block type builds. I am kind of scared of fabbing my own motor mounts, but I don't see why I couldn't. Basically it boils down to the transmission/motor mounts though from what I have seen. That and header/oil pan clearance. I will keep searching.
Old Sep 12, 2008 | 05:03 PM
rskrause's Avatar
Moderator
A 400 is not a "big block". It is a big bore small blcok with the same external dimensions. The big block is much bigger. BBC's have 4.84" bore spacing and SB's are 4.4", and son. A BB weighs close to 100lbs more than a small block.
Rich
Old Sep 12, 2008 | 05:10 PM
mdacton's Avatar
to maintain a big block would be a huge hassle in the 4th gen chassis, depends on how bad you want it...
I would evaluate how much power/tq etc. you want and the use of the car....
Then find something else that can fill the need.
Old Sep 13, 2008 | 08:13 AM
tomcowle's Avatar
Aww Mike don't suck the fun out of it.
If you have a lift, working on a 4th gen big block isn't that bad as long as your not trying to keep the AC,Cruise and etc.
Old Sep 13, 2008 | 09:49 AM
96LT1TX's Avatar
I already don't have AC, cruise etc. I have my own engine hoist. I was thinking about some 408 I saw written up a long time ago that peaked my interest, I could be wrong about the size. I just remember it was a big block in an LT1. It is a gutted drag car that just isnt fast enough. I want to run a 120mph in the 1/4 basically N/A and then spray on top of that is my goal now. I want to do a turbo LT1, but it seems like such a hassle honestly. I wish LT1 heads werent so damn expensive.
I just want something easier to work on than an LT1 honestly. I am sick of the LT1 because of the reverse cooled heads, the water pump directly above the distributor, the opti in general, the crappy cast intake manifold that has chipped in a few places on me, etc. I might even go LS1 just for ease of everything.
Old Sep 13, 2008 | 03:51 PM
ulakovic22's Avatar
There are a couple active threads right now, one in Advanced Tech and I have one in Gen F-Body forum.
https://www.camaroz28.com/forums/sho...ight=BBc%2FT56
Old Dec 5, 2008 | 12:20 PM
reamo04's Avatar
go turbo LT1, you dont have AC already so that makes it that much easier. Talk to RealQuick and he can get you a complete turbo kit for less than your going to spend building a BBC. Hell, he has a TT setup on ebay for 1750 right now, but then you need turbos (two t70s at 600/piece for well over 1200RWHP)
Old Dec 5, 2008 | 02:09 PM
<Puck>'s Avatar
If you think LT1 heads are expensive I don't think you should be looking at turbo/bbc fourth gen builds!!
To me it sounds like the least expensive way to meet your goals would be some ported TFS or darts and a solid roller setup, and selling your LE1s to recoup some losses. Still easily 3k+ investment, but that is many times cheaper then a bbc conversion once all is said and done.
For a street car ported stock castings are great, but if you are looking for a lot of power with a stroker then aftermarket casting may be a worthwhile investment.
Old Feb 7, 2009 | 12:00 PM
96LT1TX's Avatar
Ya, I came back to this finally. The money isn't necessarily the issue. I just don't want to dump a lot of money in the car honestly... I have always believed in doing it the cheapest possible. I have been thinking for years about the turbo set-up. I just can't justify letting someone do all the design work, that is the fun part.
For the turbo set-up I need to rebuild the motor though with some beefier internals and the tune would be quite intensive. I have never found a tuner who would help me besides mail-order type stuff so I have started tuning myself with questionable results.
The aftermarket heads and solid roller is where I think I am going now, I just want to find the cause of my "knock" issue that has plagued this motor. Is it just loud valvetrain etc.
Old Feb 7, 2009 | 04:31 PM
kgkern01's Avatar
If you only want 120 mph in the quarter, you can easily get that with an LT1, some good ported heads, custom cam, 383/396ci and right supporting mods and that should be not be too difficult to do. I'm aiming for 118-120 mph in the 1/4 with LE3 heads, custom cam, 385ci, and running on E85.
MadMav
Feb 6, 2015 11:02 PM
RedLineRev
Jan 23, 2003 03:51 PM
Skull Leader
Aug 10, 2002 11:01 AM
Eric H
Aug 10, 2002 06:39 AM
Doug Harden
11
Jul 14, 2002 04:31 PM
