early timing chain conversion to later style
Old Jan 31, 2010 | 11:12 AM
4SFEDZ's Avatar
i have a 94 and want to run a double roller. and need to know what all i need to convert.
items i will need
later style timing cover, and a little grinding
later opti
electric wp
what else? do i need to change pins on the cam? if so can i just change the pin with out having to get a new cam?
that it?
Old Jan 31, 2010 | 12:35 PM
The 95-97 cam has a larger pilot hole in the end of the cam to support the 95-97 vented Opti shaft:
Old Jan 31, 2010 | 01:09 PM
Stl94LT1's Avatar
You'll also need a 95-97 opti wire harness and vaccuum harness.
Old Jan 31, 2010 | 01:53 PM
4SFEDZ's Avatar
wow, thanks man, those are some awesome pics! U R THA MAN! do you think i could drill out the cam gear, and cam for the cam gear to fit into, and get a longer pin? man i dont wanna change my cam!!!!!
Old Jan 31, 2010 | 01:55 PM
4SFEDZ's Avatar
is the plug on the harness itself different on the 95-97 than the 93-94? the msd opti had the harness and vacuum lines with it.
Old Jan 31, 2010 | 01:59 PM
Stl94LT1's Avatar
Yes.
If you are running an aftermarket camshaft it will have the bigger hole, you'll just need to change the dowel pin.
Old Jan 31, 2010 | 02:41 PM
4SFEDZ's Avatar
where can i get the longer dowl pin?
nikolt1
Feb 27, 2015 09:10 PM
Cam's maro
Jan 30, 2015 09:21 PM
Queens94z28
Dec 20, 2014 09:11 PM
siguy
Nov 27, 2014 10:07 AM
GigaMp3z
Feb 20, 2003 02:57 PM
