intake gasket problem
So my mating surfaces were sparkly clean and I was about to install the new intake gaskets on the lt1 when I noticed a problem. Three of the four plastic intake tabs had come off inside of the head. Two of them are slightly above but barely and one is recessed deep into the hole. I thought these things were supposed to stay on with the gasket because this has never happened to me, what a pita. Everything was running smoothly too. Any thoughts? I was thinking about gluing a small object that is similar in shape to each of them to try and pull them out. The only problem with that idea is that it would take a while for the glue to harden. help
That was my initial tool of choice. The problem is even a VERY small screwdriver is almost too big and it's not able to get underneath of it. I was able to remove them by using a small food skewer and piercing through them...haha. Hey, you have to be creative sometimes. On a side note, a VERY small hooked screw driver would probably work best for this situation. However, I didn't have a tool of this sort, hence me using the skewer.
You can get even finer ones from medical equipment suppliers.... the cheap Pakistani rip-offs are more than adequate for working on your car....
http://www.indigo.com/images/product/21.jpg
http://www.indigo.com/tools/dental-picks-probes.html
