Eagle 5.7 H-Beams - Clearance Issue
Old Apr 11, 2005 | 06:25 PM
Kryckter's Avatar
I have done some searching and havent really came up with anything.
I recently did a 355 forged bottom end with eagle 5.7 H-Beam rods.
After some miles I noticed a very faint tapping, or brushing noise coming from the bottom end.
Pulled the pan to check all clearances, Rod bolts and etc. looked fine.
The windage tray had some marks, Come to find out, two of the rod bolts(ARP) were hitting the windage tray.
Just trying to help some people out and let them know, Always check the clearances, Even the ones you wouldnt expect.
Old Apr 11, 2005 | 08:10 PM
ulakovic22's Avatar
Re: Eagle 5.7 H-Beams - Clearance Issue
I had the same problem, except mine were 6" rods. I just left mine off instead of clearancing it.
Old Apr 11, 2005 | 09:25 PM
rskrause's Avatar
Moderator
you are missing out on some "free" hp by not running a windage tray.
Rich
Old Apr 11, 2005 | 10:23 PM
Kryckter's Avatar
Yeah I just clearanced the windage tray, Little banging goes a long way,
Also grinded on some rod bolts, They were a little too close to the pan rails on the block.
Joseph
ZDriver96's Avatar
yes.. Eagle rods w/ ARP bolts will have clearance issues.
Your best option is to get longer studs for your main caps. Studs from a 400+ big block.. GM has them..
THat way you can lower your windage tray closer to the oil pan and still have enough thread on the stud to put your jam nut back on to hold the windage tray in place..
Old Apr 12, 2005 | 12:04 AM
Spinner's Avatar
Joseph
Grinding something like a rod bolt doesnt seem like a bright idea to me.
Old Apr 12, 2005 | 12:06 AM
Kryckter's Avatar
Seen it done pretty often, Grinding a very small amount (< .040") to get the proper clearance doesnt seem that bad, especially on the head of the bolt
Old Apr 12, 2005 | 12:07 AM
roadtrip120's Avatar
Its the head of the bolt, like it changes the strength of the bolt, nore does it affect the torque anyway
LeftoverChinese
Jan 14, 2024 03:03 PM
Drtryder
Apr 22, 2015 04:17 PM
camaro98_speed
Wheels and Tires
Mar 17, 2015 07:36 AM
Jonnybegood
Parts Wanted
Feb 10, 2015 07:50 AM
Catmaigne
Dec 25, 2014 12:16 PM
