E-Brake
Old Sep 3, 2003 | 11:01 PM
ERIK93Z's Avatar
Wink E-Brake
93z,car towed with e-brake on.Now when
I set e-brake handle goes all the way up.
If I park with a slight grade in driveway or
on street e-brake doesn't stop car.My pads
were going out so I changed them thinking
this correct or help the problem but no
such luck any suggestions?I heard the calipers
can be adjusted.any help thaks!
Old Sep 3, 2003 | 11:25 PM
scoobysnax83's Avatar
it should automatically adjust. Have you checked to make sure that the cable did not snap?
Old Sep 4, 2003 | 12:37 AM
Dolby109's Avatar
Who towed it with the E-brake on?
Did you leave it on, or them?
If they left it on, I would contact them about fixing it (although it may be too late at this point).
Anyway, when you pull the handle is there any resistance? If not the cable is probably snapped.
Old Sep 4, 2003 | 08:41 AM
Smoke T/A's Avatar
Sounds like the cale broke. If not than it needs to be reajusted.
Old Sep 4, 2003 | 05:50 PM
BOWTYDE's Avatar
Do you readjust them?
Old Sep 4, 2003 | 06:06 PM
AustinZ28's Avatar
I'm having the exact same symptoms as listed above. If my cable is broken, how do I hook up a new one? --AZ28
BoobSter-lt1-z
Feb 7, 2004 03:50 AM
Ferocity02
Sep 11, 2003 02:37 PM
ERIK93Z
Sep 3, 2003 01:33 AM
ip305
Mar 6, 2003 04:57 AM
Tires_Smokin
Feb 7, 2003 01:55 PM
