Dyno'd my car today.
Old Oct 26, 2005 | 08:18 PM
  #31
BlackDog's Avatar
Re: Dyno'd my car today.
Originally Posted by SStrokerAce
Scott,
You need to have you deck height (or how far the piston is in the hole) along with the head gasket specs to know the CR.... it could easily vary from 10.25-11:1 with that setup.
Bret
Bret,
The shop said the deck was zero'd out, if you mean with the piston is at tdc then the piston was level with the deck if I remember correctly and the dish is a -15. The gasket is .039.
Scott
Old Oct 26, 2005 | 08:41 PM
  #32
SStrokerAce's Avatar
Ok so you are at the 11:1 range with that then.
Bret
Old Oct 28, 2005 | 05:10 AM
  #33
BlackDog's Avatar
Bret
Thanks Bret for taking the time to that.
Scott
Old Oct 28, 2005 | 05:44 PM
  #34
BlackDog's Avatar
What's your thoughts in using one of these cams for my setup from Lunati:
232/242 .544/.560 with 1.6 rr 108
242/252 .560/.576 with 1.6 rr 108
Scott
Old Oct 28, 2005 | 06:16 PM
  #35
93turbo5oh's Avatar
i wonder how much of the problem stems from the unported lt4 intake.
Old Oct 28, 2005 | 06:32 PM
  #36
Kreinmc's Avatar
Probably 2 hp.
Old Oct 28, 2005 | 07:00 PM
  #37
THEMADTYPH00N's Avatar
I don't know a whole lot here but my guess is that those stock heads and intake can't feed the larger displacment. You would probably see some good gain with ported heads so they can feed the larger volume of air need to feed the extra cubic inches.
Old Oct 28, 2005 | 08:45 PM
  #38
ABA383's Avatar
I think someone said this earlier, but just run it at the track. As long as your tune is good, A/F ratio, timing, etc, then just run it and your mph will tell you whats going on. I got bashed a while ago for my "low" dyno numbers and my "too small" cam and just ran a 11.51 @ 118 with a 1.55 60'...my dyno numbers from 2 different dynojets ranged from 362-400rwhp and 352-430 rwtq...I guess it all depends on what you want...high dyno numbers or good track times/mph..Don't get too caught up in the dyno numbers...run it at the track and see...
--Alan
Old Oct 28, 2005 | 09:19 PM
  #39
93turbo5oh's Avatar
Originally Posted by Kreinmc
Probably 2 hp.
based on my conversations with Phil at AI thats not what i have been led to believe. but OK.
Old Oct 28, 2005 | 09:51 PM
  #40
Z95m6's Avatar
Well this guy has stock heads, so i imagine thats the biggest factor right now.
Steve69SS396
Track Kill Stories
15
Aug 10, 2015 02:45 PM
birdblack
Dec 30, 2014 06:59 PM
USAirman93
Nov 24, 2014 03:37 PM
97 RedSS
Jun 10, 2003 07:58 PM
Burn_Out
Aug 18, 2002 08:49 AM
