Dyno results
Re: Dyno results
no there arent any loops at all the power is climbing pretty good and then falls right off. I am going to have my pcm redone to richen it up a little and check adjustment of the rockers. Is there a way to tell the difference between stock and aftermarket springs with them installed? The only other thing that i can think of that would hurt my top end is my exhaust, i think the y pipe is a little restrictive so i am also ordering 2 cutouts to put after the headers
Re: Dyno results
It sounds like someone got off the gas too soon to be honest.
No AFR change can cause a 100hp dip. When you do send back the computer make sure you include the AFR chart so Bryan can hook you up.
Re: Dyno results
yeah i am going to send all the graphs with it, but i was driving it and did not let off until 6400 on either pull. I was driving it home form school today and got in it with the windows down and it seems like it might be missing pas 6000 so i guess i am going to pull the valve springs and see what they are i dont really know what else to do?
Re: Dyno results
Did I meet you at Stanton the other week, Sunday April 11th? I was in line in front of you in the lanes. If it was you, weren't you trapping like 110+ mph? If so, your HP is most likely higher than what the dyno is showing.
Dan
Dan
Re: Dyno results
yeah i met you up there that weekend, she was running decent then but had traction problems in second. What should i do as far as upgrading my ignition? Full MSD set up or is a coil enough for the mods i have. I think i am going to trying changing my plugs and gapping them a little less, otherwise i dont know because the opti was recently replaced along with taylor wires.
Re: Dyno results
Re: Dyno results
I hate to interject but.. i thought the hotcam was 218/228 @ .050", .525" intake and .525" exhaust and 114 LSA for the lt1.. the LS1 is 219/228...
Cant really find the LSA specs.. but I always thought it was 114....could be wrong.
--Troy
--Troy
Re: Dyno results
--Troy
--Troy
Dan
tdigger9899
Sep 7, 2015 10:56 AM
