Dyno results
Old Apr 20, 2005 | 10:15 PM
  #16
Black6spdZ's Avatar
Re: Dyno results
no there arent any loops at all the power is climbing pretty good and then falls right off. I am going to have my pcm redone to richen it up a little and check adjustment of the rockers. Is there a way to tell the difference between stock and aftermarket springs with them installed? The only other thing that i can think of that would hurt my top end is my exhaust, i think the y pipe is a little restrictive so i am also ordering 2 cutouts to put after the headers
Old Apr 21, 2005 | 12:23 AM
  #17
Alvin@pcmforless.com's Avatar
Re: Dyno results
It sounds like someone got off the gas too soon to be honest.
No AFR change can cause a 100hp dip. When you do send back the computer make sure you include the AFR chart so Bryan can hook you up.
Old Apr 21, 2005 | 09:48 AM
  #18
Black6spdZ's Avatar
Re: Dyno results
yeah i am going to send all the graphs with it, but i was driving it and did not let off until 6400 on either pull. I was driving it home form school today and got in it with the windows down and it seems like it might be missing pas 6000 so i guess i am going to pull the valve springs and see what they are i dont really know what else to do?
Old Apr 21, 2005 | 11:07 AM
  #19
stereomandan's Avatar
Re: Dyno results
Did I meet you at Stanton the other week, Sunday April 11th? I was in line in front of you in the lanes. If it was you, weren't you trapping like 110+ mph? If so, your HP is most likely higher than what the dyno is showing.
Dan
Old Apr 21, 2005 | 01:14 PM
  #20
BIG SHAFE's Avatar
Re: Dyno results
Are you running the stock ignition? If I were to build up an engine, one of the first things i would do is upgrade the ignition, it definitly could use a stronger spark.
Old Apr 22, 2005 | 07:09 PM
  #21
Black6spdZ's Avatar
Re: Dyno results
yeah i met you up there that weekend, she was running decent then but had traction problems in second. What should i do as far as upgrading my ignition? Full MSD set up or is a coil enough for the mods i have. I think i am going to trying changing my plugs and gapping them a little less, otherwise i dont know because the opti was recently replaced along with taylor wires.
Old Apr 22, 2005 | 07:40 PM
  #22
CamaroBoy96Z28's Avatar
Re: Dyno results
I'm doubting that adding an MSD box is going to help. An aftermarket coil wont be any better than stock 96-97 single connector style but could help marginally with the 93-95. I didnt look at your sig to see what year you have. Regardless there's an underlying issue causing your power to drop of radically. Since it happens at 6k+, valvetrain would be first option. Check what springs you have and go from there.
Old Apr 22, 2005 | 08:06 PM
  #23
Black6spdZ's Avatar
Re: Dyno results
what is the best way to tell what springs are on it? Could it be a weak fuel pump?
Old Apr 24, 2005 | 12:17 AM
  #24
TMorgan800's Avatar
Re: Dyno results
I hate to interject but.. i thought the hotcam was 218/228 @ .050", .525" intake and .525" exhaust and 114 LSA for the lt1.. the LS1 is 219/228...
Cant really find the LSA specs.. but I always thought it was 114....could be wrong.
--Troy
Old Apr 24, 2005 | 12:20 AM
  #25
Re: Dyno results
--Troy
You have it right, except it is on a 112 LSA. For the LT1: 218/228 0.525"/0.525" with 1.6 rockers 112 LSA
Dan
fift5
11
Oct 1, 2015 10:31 AM
HAWG
Sep 25, 2015 11:41 AM
Daluchman1974
Sep 11, 2015 06:12 AM
tdigger9899
Sep 7, 2015 10:56 AM
