Dyno numbers for bolt on only 95 Z28
Old Oct 27, 2004 | 04:08 AM
95z6spd's Avatar
Hey guys. i just had my car tuned by Byran from PCMforLess yersterday. The car is totally stock internally but has every single other bolt on. Before his tuning with the hypertwech it made 295 rwhp and 323 rwt. After his tuning it put down 311 rwhp and 344 rwt. I then opened the cutout and surprisingly it didnt gain any horsepower but gained 3rwt. All in all I was pleased. I picked up 16rwhp and 20rwt. The car does feel faster and now I can go for the record for totally stock internal LT1 w/6spd. I belive it is 12.48. Everyone wish me luck. November 11th will be the day.
Old Oct 27, 2004 | 07:02 AM
IllusionalTA's Avatar
Re: Dyno numbers for bolt on only 95 Z28
Great numbers.. Glad to see another Bolt On Lt1 over the 300RWHP mark.. MIne threw down 309/354 back in the day and was trappin mid 108's @ 3900lbs.. w/a 4.11 Gear.. Get some weight out of the car that is your ticket to low et's w/ these things.. I was too lazy to do anything to take weight out..so i've never gone faster than a 12.73 w/ a i'm too heavy 1.91 60ft..
Old Oct 27, 2004 | 09:00 AM
truedualws6's Avatar
Great Numbers. It's good to see those numbers for a stock motor
running through cast iron exhaust manifolds and a cat. I'm about
in the same situation, but also had 1.6 rockers (pre cam change)
and could only manage 293 rwhp, so you are definately doing things
right. Are your numbers SAE or STP?
Old Oct 27, 2004 | 09:50 AM
HE said stock internal not stock exhaus mani's.. Hmmm I thought i seen mac's i dunno.. either way great numbers..
Old Oct 27, 2004 | 10:33 AM
GREGG 97Z's Avatar
Sounds like you have a very strong running LT1 there. Where are you running around here on the 11th? I want to run at the Grove this Sat but its looking like rain now.
Old Oct 27, 2004 | 10:34 AM
jbsupra89t's Avatar
great numbers, so if you dont have headers, and still have a cat, what other mods do you actually have?
-J
Old Oct 27, 2004 | 10:39 AM
Dexter's Avatar
Yea those good numbers I very close to that with my A4 but I haven't ran better than 13.8@99mph I'm not happy.
Old Oct 27, 2004 | 11:21 AM
???? How are you close? your et and your mph match up kinda sorta.. whats your 60ft? etc? Mods?
Old Oct 27, 2004 | 12:28 PM
95z6spd's Avatar
Sorry guys. My sig is old. I now have Hooker long tubes with a Mufflex ory pipe. The numbers are STD On the 11th of Nov, me and 14 other guys are renting Atco to ourselves. the weather should be perfect and the track will be prepped with VHT. I should be able to get the 6sp, near full weight bolt on only record
Old Oct 27, 2004 | 12:41 PM
jbsupra89t's Avatar
ahhh now it makes sense, regardless, great numbers. good luck shooting for the record
Old Oct 27, 2004 | 01:03 PM
Alvin@pcmforless.com's Avatar
Good numbers!
Old Oct 27, 2004 | 02:38 PM
Ahhh STD.. Cool none the less.. GOod luck at the track.. guaranteed to be a 12 sec. pass if all goes well.. which ain't nuthin' to sneeze at..
Old Oct 27, 2004 | 02:42 PM
Project Ghost's Avatar
Good luck with it! 12.xxx is good for any internally stock LT1. Especially when you're doin it in a 6 speed!
Old Oct 27, 2004 | 02:57 PM
95z6spd's Avatar
Well i've been in the 12's for a while now...It really should be low to mid 12's on the 11th..I know SAE numbers are usually a lil lower then STD but in my case I dont think it would change much. I believe SAE correctrs it to 70 degrees and a few other corrections. The temp when the dyno run was 66 so its probably pretty close.
Old Oct 27, 2004 | 11:15 PM
Definately good numbers. The difference between STD (or STP) and SAE
is very close to 4%. STP meaning "standard temperature and pressure", which
makes your numbers 299/330. After my first dyno I found out the same thing
regarding the calibration. Most dynos are set up for SAE, but some, like the
superflow I used, was set up STP (or as you said STD).
If you have longtubes as mentioned earlier then I'm still hanging in there with
my stock exhaust manifolds through catalytics. I'm participating in a dyno tune
on Friday so it will be interesting to see the difference since I put in the Crane
227 and port matched the exhaust manifolds, oh yeah, and the 3.73s.
