Dyno numbers for bolt on only 95 Z28
Old Oct 27, 2004 | 11:20 PM
  #16
dmoor88's Avatar
Re: Dyno numbers for bolt on only 95 Z28
hey truedual. i just wanted to ask...what's the deal with not wanting any sort of headers? you went to the extent of installing a cam, springs and rockers and even added true duals but you haven't touched your stock manifolds Any reason for that?
Im not trying to come across as an a$$, I was just curious.
Old Oct 27, 2004 | 11:41 PM
  #17
truedualws6's Avatar
No problem on the question. It is a very strange desire, but I have had my
cars with headers, and have really enjoyed them. For my current car, I want
to keep it looking and sounding very close to stock, including passing all CA
smog requirements. So far I think I have accomplished that. Also, I feel that
my exhaust system is getting me 15 rwhp over any comparible system with
catalytics and full smog. This helps make up for the no-header handicap.
Considering how quiet my car is, and the cast iron manifolds, I'm really happy
with the 293 rwhp. If all goes well I may get that up in the 320-330 range on
Friday.
Old Oct 28, 2004 | 06:05 AM
  #18
IllusionalTA's Avatar
Originally Posted by truedualws6
port matched the exhaust manifolds, oh yeah, and the 3.73s.
Man you were oh so close.. had the manifold's off and everything.. Some will power you got there...
Old Oct 28, 2004 | 08:32 AM
  #19
95z6spd's Avatar
Is it just a standard 4% calibration difference or does it vary depending on the actual conditions of the test? Good numbers through the manifolds. I actaully have run a 12.786@106.72 @950DA through the stock manifolds and a single highflow cat. I think I nedded the tune to get the most out of the longtubes. Good #'s to you as well trualdual. The only maijn difference is the torque Torque is GOOD. My car is also putting it down through the moser 12bolt w/4.10's
Old Oct 28, 2004 | 09:36 AM
  #20
jbsupra89t's Avatar
damn this is getting me more and more excited to dyno my setup...
-J
Old Oct 28, 2004 | 09:45 AM
  #21
This is from a response to a question I asked a Superflow contact:
SAE -- The SAE standard applied is a modified version of the SAE J1349 standard of June 1990. Power is corrected to reference conditions of 29.23 InHg (99 kPa) of dry air and 77 F (25°C). This SAE standard requires a correction for friction torque. Friction torque can be determined by measurements on special motoring dynamometers (which is only practical in research environments) or can be estimated. When estimates must be used, the SAE standard uses a default Mechanical Efficiency (ME) value of 85%. This is approximately correct at peak torque but not at other engine operating speeds. Some dynamometer systems use the SAE correction factor for atmospheric conditions but do not take mechanical efficiency into consideration at all (i.e. they assume a ME of 100%). SuperFlow uses a more sophisticated algorithm for calculating friction torque, based on a summary of thousands of friction power tests performed by the automotive industry. This proprietary algorithm estimates friction torque as a function of piston speed and engine displacement.
STP -- The STP (also called STD) standard is another power correction standard determined by the SAE. This standard has been stable for a long time and is widely used in the performance industry. Power is corrected to reference conditions of 29.92 InHg (103.3 kPa) of dry air and 60 F (15.5°C). Because the reference conditions include higher pressure and cooler air than the SAE standard, these corrected power numbers will always be about 4 % higher than the SAE power numbers. Friction torque is handled in the same way as in the SAE standard. Once again, this means the STP corrected power displayed by your SuperFlow test system will be more accurate than power numbers obtained using a default Mechanical Efficiency of 100% or 85%.
Old Oct 28, 2004 | 10:01 AM
  #22
all my Dyno #'s are through a 9" w/ 3.70's.. You guy's are getting some great number's.. Keep on carryin' that LTx flag waving high..
Old Oct 28, 2004 | 10:07 AM
  #23
JZ 97 SS 1500's Avatar
Actually the bolt-on record is 11.94 @ 111.5 by Sar2K with a 6spd. The 12.48@110.5 was the previous record....I know this since the 12.48 was done by me...hehe.
Jose
Old Oct 28, 2004 | 11:25 AM
  #24
95z6spd's Avatar
Sar2k is an auto with a BIG stall converter....So then i guess you still have the 6spd record..until the 11 th
Old Oct 28, 2004 | 11:35 AM
  #25
Your right...well thats cool. Guess I still have the record. That was done about 5-6 years ago. Just typical bolt-ons, 3715lb race weight.
Jose
Old Oct 28, 2004 | 12:26 PM
  #26
95z6spd's Avatar
JZ you had stock rockers too right or roller rockers?
Old Oct 28, 2004 | 01:26 PM
  #27
cndctrdj's Avatar
i love seeing a stock lt1 go fast. mine would have been up thier if i hadnt blown the head gasket. o well time to put some more boltons in thier. good luck on the 11th
Old Oct 28, 2004 | 02:10 PM
  #28
Haskin Z28's Avatar
mines getting up there for an A4, times in sig, stock stall stock rockers flowmaster exhaust...just installed 1.6 comp ro mags need some tuning and ill post some new numbers
Old Oct 28, 2004 | 03:06 PM
  #29
97bowtie's Avatar
You'll have some good competition for that record pretty soon. Look for KreinMC's dyno numbers/track times. He should be running pretty well.
Good numbers.
Old Oct 28, 2004 | 03:13 PM
  #30
Zeueses 97 RamAir's Avatar
is that with headers mine put down 310 348 pounds of torque with 342s then went 410s and my opti started to misfire up top and it put down 298 330 pounds of torque, i guess you do loose power with gears..
