dying on side of road
Old May 14, 2013 | 01:18 PM
  #16
xxjman's Avatar
Angry Re: dying on side of road
Originally Posted by Chet1185
Thanks for the help and info guys. I will be changing the opti tomorrow. I've done this so many times I can almost do it with my eyes closed which isn't a good thing.
Posted from Camaroz28.com App for Android
I've had the same thing happen to me also was getting low res pulse code. It turned out to be my the indexing pin on the bottom of the rotor. When I replaced it the last time the ping broke off in the hole so the new rotor was not fitting flat this caused the optical wheel to rub on the sensor overheating it shutting down the motor. I removed the broken pin and all has been fine for months now.
Old May 14, 2013 | 11:37 PM
  #17
Chet1185's Avatar
Will, got to the opti today, took it off, and it just poured oil out of it.so now I need to replace the timing cover gasket and the seals.
Is there anything I have to make sure I do?
Old May 14, 2013 | 11:53 PM
  #18
slick1hunting's Avatar
yeah lol. The seal needs handled with care. you want the lip to not fold or tear. You also want to drive it in straight. When I did mine there was a good youtube video on doing it. He used a socket(actually I think started with a smaller one to loosen it up a bit. I have a bookmark on my phone from another site that is also helpful. Will look for it.
Old May 14, 2013 | 11:55 PM
  #19
</title> </head> <body> <table width="100%" height="152" border="0" background="darkbluegradient.gif"> <tr> <td width="27%" height="128"><img src="vaderheader.jpg" width="100%" height="129"></td> </tr> <TR> <td width="100%" height="24" align="CENTER"
Old May 15, 2013 | 08:56 PM
  #20
ACE1252's Avatar
I have a set of these to install seals.
Lisle 12980 Bearing and Seal Installer Master Set : Amazon.com : Automotive
Make sure you drive the seals in square. No oil on the outer edges of the seal. Make sure all surfaces are clean.
Old May 17, 2013 | 02:44 PM
  #21
Chet1185's Avatar
Well took the timing cover off and the whole pan gasket needs replaced. It is a mess of oil and sludge everywhere. I have the manual in the car and it doesn't seem to hard to change the oil pan gasket but from experience of someone else doing it, is it difficult? I did just do an engine change in my TA, so hopefully I can change the oil pan gasket.
Old May 17, 2013 | 02:57 PM
  #22
Chet1185's Avatar
Would this work?
"I replaced my oil pan gasket a number of years back, but I 'cheated' and didn't remove the pan all the way.
- Drop the pan as far as you can go, like an inch or so. - Take the new gasket and slide it *under* the pan, such that it is sitting under the oil pan, against the K-Member. - Gently (!) stretch it, one side and then the other, onto each pan rail. - Inspect to make sure you didn't tear it. Mine had no issues. - Voila, only 10 minutes spent."
Old May 17, 2013 | 03:14 PM
  #23
ive seen a similar post. I recently pulled my pan to change the oil pump. What I did to create the needed room to get pan out was dropped the large bolts holding kmember up but left the strut bolts that go in fender area. I held motor up with the happy hooker and pulled the single bolt on each side of motor mount. That gave me enough room to get aftermarket pan off and back on. just changing gasket should be alot easier. Be sure you apply silicoln in the areas it is needed( dont remember now because my gasket stayed in place when I put aftermarket pan on and when changed oil pump.
guruerror
Dec 12, 2020 06:32 PM
akwa
Apr 5, 2015 05:09 PM
ChrisFrez
Feb 22, 2015 08:47 AM
pimpss96
Feb 12, 2015 01:28 PM
derty
Apr 22, 2011 01:14 PM
