dumb question
Old Jun 20, 2004 | 08:11 PM
lt1g3n's Avatar
dumb question
anyone ever install a balancer hub / damper / and the ud pulley with out a balancer removal/installer tool ? Like just taking turns torqueing them to a certain lb ?
Just curious, i wanted to get some work done tonight but unfortunately everything is closed :P , damn work tomarrow and the next day and the next day and the next, but i spose i can wait if thats a very bad thing =P thanks.
Old Jun 21, 2004 | 12:04 PM
RealQuick's Avatar
Re: dumb question
I never used an installer. i just drew everything in with the bolt (or bolts depending on if its the damper/pulley or the 3 prong hub). Once it draws in all the way you can torqe it. If your installing the hub on the crank, you can use a block of wood against the front and hit it on with a mallet.
Old Jun 21, 2004 | 08:21 PM
lt1g3n's Avatar
well nice thing is the pulley was already torqued on with the 3 style installer, so all i have to put on is the hub itself witch is only one bolt , so i guess all is well
thanks
ModdedNerd
Dec 25, 2014 05:51 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
donot_4get
Sep 14, 2002 08:03 AM
