oil leaks
Old Jun 21, 2004 | 01:42 PM
Fry's Avatar
Fry
oil leaks
My car leaks oil, about a pint a month, but I don't want to fix it 'cause I will be rebuliding the engine anyway, is there a way to slow the leak with some kind of additive? What should I use
Old Jun 21, 2004 | 03:34 PM
valter's Avatar
Where it's leaking from? May be it's not that bad to fix a leak. I do not recommend adding anything to oil - more expensive problems can appear. You can try heavier weight oil though, not sure whether it will help, it helped me on Crown Vic.
Old Jun 21, 2004 | 07:30 PM
Fry's Avatar
Fry
It's leaking from the front and rear seals....and one of the head gaskets
Old Jun 21, 2004 | 08:24 PM
valter's Avatar
That doesn't sounds very good... I'd switch to 10w30 or even 15w50 on summer. A lot of people will argue on that. Just do not put load on engine when it's not warmed up.
Magenta_Hearts
Mar 29, 2017 08:54 PM
surreybrad
Apr 22, 2015 06:40 AM
BigWil
Mar 29, 2015 12:24 PM
artic94
Jan 17, 2015 11:19 AM
