dumb cam/heads install question????
Old Jun 18, 2003 | 09:20 PM
QCKZ28's Avatar
ok heres the deal my opti is barely touching my crank pulley on the driver's side but is clears normally on the pass side. im using a double roller timing set, the timing gears were aligned, hub installed and torqued correctly along the pulley, what could cause this, the opti went on smooth and flush. i had to grind the dowel pin down a little on the cam to match the stock one. any ideas
Old Jun 18, 2003 | 10:11 PM
What did you do about the crank position sensor and the reluctor for it? If you did not put the reluctor back in, you need to put it back in or use the pre-96 hub (it has a longer snout).
Old Jun 18, 2003 | 10:20 PM
QCKZ28's Avatar
i ground off the CPS to fit for the double roller and i left the reluctor ring off becuase their was barely enough room for the crank gear after i grinded the cover down with a dremel. so would the only way to fix this be to buy a pre 96 hub???
Old Jun 18, 2003 | 10:25 PM
Now your hub is too short, because the reluctor is gone. That causes your pulley to be moved in closer to the engine and throws your belt alignment off, too. The pre-96s don't have the sensor/reluctor and therefore have a hub that is longer. You will need the older hub.
Old Jun 18, 2003 | 10:31 PM
QCKZ28's Avatar
thanks shoebox, i just about messed up i will order a 95 keyed hub from thunderracing tonight and have it overnighted, of all the research ive done,i somehow overlooked that aspect. thanks again
Jesse
ModdedNerd
Dec 25, 2014 05:51 PM
Queens94z28
Dec 20, 2014 09:11 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Noenav
Dec 6, 2014 07:35 PM
