What's the point of a windage tray?
Old Jun 17, 2003 | 02:25 PM
Phatcaprice's Avatar
It seems under high rpm's, wouldn't you want the oil in the oil pan rather than sitting on top of the windage tray?
Old Jun 17, 2003 | 02:44 PM
TedH's Avatar
Windage trays keeps the oil from foaming.
Old Jun 17, 2003 | 03:10 PM
InjectedSS's Avatar
from foaming wtf? since when does oil foam?
its to keep oil from splashing up onto the crank, causing you to loose HP! it wont hurt anything to NOT have one! you might loose like 2HP thats about it
Old Jun 17, 2003 | 03:30 PM
Lab's Avatar
Lab
I am no expert and I am sure others here can answer better that I. But my understanding is that at high rpm's the oil can "wrap" around the crank and is slung off. You want to scrap the oil off the crank and then keep it in the pan so the oil pump can pick it up. The crank can whip the oil so much that air bubbles form in the oil, which does your bearings no favors, plus the oil "drags" the crank and takes away a few horsepower.
The best set up is to use a dry sump lubrication system in which external scavenger pumps suck all the oil out of the pan and pump it back into the engine externally. But this is very expensive and for street use a normal wet sump system is more than adequate.
Lance
Old Jun 17, 2003 | 03:46 PM
treyZ28's Avatar
From: looking for a flow bench so Brook and I can race
your all right-
yay! everyone is a winaaaar!
(except for the part when injectedss said oil cant foam )
Old Jun 18, 2003 | 07:32 PM
Fast Caddie's Avatar
It also helps with the transfer/movement of air inside the crankcase as the rotating assembly does its thing.
Old Jun 18, 2003 | 07:51 PM
IrocManiac's Avatar
Oil can foam, at 5000+RPM you'd be surprised at all the things motor oil CAN do.
Old Jun 18, 2003 | 08:21 PM
Silver's Avatar
Thumbs down
Oil can foam. Oil does foam. Oil will foam.
Geez, spoken with such confidence... these falacies.
Old Jun 18, 2003 | 10:48 PM
Technically, oil doesn't "foam." But it can become "arreated."
There is a difference
93 RedBird
Nov 15, 2015 08:24 AM
68camaroboltz
Oct 5, 2015 01:46 PM
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
Bigtoyz97
Sep 21, 2015 01:44 PM
alliance12364
Sep 17, 2015 08:43 AM
