Dumb auto tranny question
Old Apr 30, 2003 | 05:12 PM
  #16
stangitr's Avatar
Thanks for the info guys. I'll be spending a lot more time in the LT1 tech forum as soon as I get back home and start driving/working on my new car I didn't realize a complete rebuild would be that much though
Old Apr 30, 2003 | 08:35 PM
  #17
My94RedZ28A4's Avatar
Originally posted by frmula1
thats whats happening with my car... it won't shift from 2-3... all i need is a solenoid?!?!?!.... i been looking at 2500 to fix it... and i been driving around and now this grinding starts.... read my posts on "oh my god im about to jump off a bridge" help me out PLEASE im between a huge rock and a hard place
frmula1 I honestly can't say for certain that is what the problem is. I can say that if you scan your computer and pull the same code, then it is probably the cause of it. It's a very easy fix, drop the pan, pull the wires off, pull the clip, remopve the solenoid, insert the new one, replace the clip, replace the wires, bolt it back up and fill it with fluid.
I also put in a drain plug because I don't like showering in ATF every time I change the fluid. I did a filter change as well. All in all it took me about 2 hours, mainly because of the drain plug (I am **** and wanted it in the *perfect* place) If I had only switched out the solenoid, it would take maybe 20 minutes.
ChrisFrez
Jan 18, 2015 08:05 AM
ChrisFrez
Jan 11, 2015 03:47 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
tds1213
Nov 27, 2014 12:55 PM
Snoman73
Nov 17, 2014 07:22 PM
