Dumb? 2 bolt vs 4 bolt main
this has to do with the main bearing caps. They either have 2 bolts, or 4 bolts.
More bolts = more strength. personally i would keep a 2 bolt main and splay the block to a 4 bolt. I feel the 2 bolt lt1 is a superior casting.
Plus, billet main caps are alot stronger than what comes stock. Also, splayed mains have the outer bolts drilled at an angle instead of straight up and down. Much stronger than a standard 4 bolt main block.
Victor Lamb
Aug 26, 2017 02:52 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
