DTC 51 ...what does it mean?
Old May 10, 2006 | 11:04 PM
Sparkz28ss's Avatar
I have a DTC 51 .....PROM error (faulty or incorrect PROM)
......thats random..... I get the code and then my car runs like crap
Old May 10, 2006 | 11:25 PM
tapout911's Avatar
Re: DTC 51 ...what does it mean?
It usually means the pcm is junk. I get it sometimes if voltage drops really low. Reset the pcm and see if it returns
Old May 11, 2006 | 01:15 AM
Sparkz28ss's Avatar
I have reset it
Old May 11, 2006 | 07:25 AM
It often accompanies a DTC 16 for the opti.
Old May 11, 2006 | 12:08 PM
Sparkz28ss's Avatar
I just put in a new opti not even 1000 miles ago....
Old May 11, 2006 | 03:04 PM
Sparkz28ss's Avatar
I dont have DTC 16 ....just 51
Old May 11, 2006 | 04:58 PM
Sparkz28ss's Avatar
WHy would my EPROM be bad....
does that mean my tune is bad?is the ECU looking for values that are not there?...really...whats the deal!
SHOEBOX!...you are great with this stuff...help a fellow car guy out!
Old May 12, 2006 | 03:44 PM
Sparkz28ss's Avatar
O rly
Old May 12, 2006 | 07:42 PM
Mtrhds94Z's Avatar
Welllll I had that happen last fall, and i had only a 7 month old new GM opti with about 3-4000 miles on it..
I tended not to believe it was the opti, since no 16 or 36 DTC was set.. just the DTC 51[eeprom error]
No spark no injector pulses.. nothing..
So I replaced the PCM [got a tune from MadZ28 at the same time, so not a total loss ]
Still no good, so after ruling out the PCM, I tested the opti, and it was COMPLETELY dead.. My advice: check the opti out carefully before assuming it's the PCM.. the PCM's are pretty durable in these cars..
I also posted on here, and got minimal replies.. it's not a common failure..
I did get another opti on warranty tho .. it took a while for the credit but I did get it..
Old May 12, 2006 | 10:00 PM
An actual PCM problem would be unusual. Low voltage, opti, poor grounds are some possibilities.
KYWes
Sep 26, 2015 08:49 AM
MDZ28
11
Sep 24, 2015 09:15 AM
tommalcolm
Sep 11, 2015 03:39 PM
MDZ28
Sep 7, 2015 09:16 PM
4586
Aug 24, 2015 11:04 PM
