DTC 41 questions
Old Feb 7, 2010 | 10:13 AM
95Blackhawk's Avatar
DTC 41 questions
Hey all,
Anyone else ever got this? It is the ICM getting more than 4.5 volts (Not sure from what but from coil I think).
I have had it happen to me 2X and both after high RPM runs.
The GM manual gives 2 solutions: change ICM or it is wiring. Seems to me that the coil could be involved.
Old Feb 7, 2010 | 10:26 AM
Guest47904's Avatar
Guest
If the IC line breaks, it will cause the pin at the PCM to go higher than 4.6 volts. If you have a weak connection at either of the 2 ends and get excessive vibration, it can momentarily loose it's connection. However, you should know that the PCM only checks for the voltage on that line when the engine is below 1500 RPMs. So how this has anything to do with racing is any ones guess.
I would check the line while wiggling the entire length and if you can't get it show that way, change the ICM AND the coil if they haven't been changed before.
Old Feb 7, 2010 | 10:50 AM
Where did you get the impression that this was a coil problem. From Shoebox's LT1 DTC list:
DTC 41 - Ignition Control (IC) circuit (open circuit)
The control circuit is the white wire to the ICM, as pointed out in the response above. The diagnostic chart starts at the white wire, and only works its way to the coil voltage supply as the last step.
dluna333
15
Mar 13, 2015 12:30 PM
jasonduaine
Mar 7, 2015 09:44 AM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
Hurin
Dec 13, 2014 07:38 PM
dreamer1q
Aug 20, 2002 11:19 AM
