DTC 29 and 32 - EAS electrical system failure??
Old May 13, 2003 | 02:31 PM
BackInBlackZ28's Avatar
Question DTC 29 and 32 - EAS electrical system failure??
Scanned my car this morning, threw two codes. One was relateds to the EGR, #32, and im pretty sure thats jus because the tube from my header to the EGR is leaking. The code i do not know what to do with was a #29, EAS electrical system failure. Only came on in closed loop, what is it and what does it mean????
Old May 13, 2003 | 03:03 PM
DTC 29 is for the AIR pump. Check the fuse.
BTW, you have 2 identical threads for this for some reason. You should delete one of them.
Old May 13, 2003 | 05:18 PM
Thanks, and i deleted the other one. Dont know where that came from...I dont have cats anymore, so how can i disable the pump without throwing a code?
Old May 13, 2003 | 08:14 PM
If you disconnect the electrical connector from the AIR pump and make sure you have a good fuse in the panel for the AIR pump, that should do it.
Old May 13, 2003 | 08:46 PM
replaced fuse, disconnected harness...good to go..Thanks!
Gtpguy
Jan 26, 2015 04:50 PM
squarehead
Jan 15, 2015 07:02 PM
Zomie
Sep 2, 2002 09:04 PM
slothgrant
Aug 22, 2002 03:01 PM
sleeperZ96BT
Aug 4, 2002 06:52 PM
