Drivetrain swap
Old Aug 5, 2021 | 07:38 AM
KYWes's Avatar
Drivetrain swap
Due to the body damage to my car and not getting encouraging words from body repair shops, I'm contemplating buying a 1996 Camaro RS and swapping my drivetrain from my car to the RS. I would drop my k-frame including the engine and transmission out the bottom and swap it into the RS, then I would transfer the complete rear end and all associated parts and accessories.
The RS is a manual 5 speed but I'm thinking the M6 should mount right in.
Anyway, anyone know why this wouldn't work?
I've found a car and buying it would be less expensive than the estimates I'm getting from the body shops. I can do all the mechanical work.
Old Aug 5, 2021 | 08:37 AM
PowerJunkie's Avatar
Re: Drivetrain swap
You'll need the harness and PCM as well but sounds like you already know that. You mentioned the k-member, as long as you swap the transmission crossmember, I don't see why it would be problem. The wiring is usually the biggest issue.
Old Aug 5, 2021 | 08:58 AM
Re: Drivetrain swap
The V8 K-member is different than the V6 K-member. It's very easy to drop the complete engine/trans/K-member/suspension /harness in one piece, roll it under the new chassis and bolt it up.
Old Aug 6, 2021 | 06:13 AM
KYWes's Avatar
Re: Drivetrain swap
Excellente'
Besides the cost, body shops in my area are swapped and backlogged until October. Very difficult to find one that will work on older cars and they are busy too. Couple that with difficulty/impossibility of finding a quarter panel shell it just made sense to me to find another one I could move my stuff to. Will be going to view the possible purchase in a couple hours.
Lots to do but being retired I've got the time.
Old Sep 28, 2023 | 12:45 PM
KYWes's Avatar
Re: Drivetrain swap
I've got the drivetrain in and cranking but not starting. I've posted a new post giving details. Would appreciate help with the problem.
https://www.camaroz28.com/forums/lt1...roblem-889851/
Old Oct 18, 2023 | 09:04 AM
KYWes's Avatar
Re: Drivetrain swap
Yeah, it's all installed. I found wiring mismatches I'm having to straighten out. It'll get done.
86305Z28
V6 Tech
Jul 27, 2006 08:28 PM
StrokinIt383
Mar 21, 2006 05:58 AM
95nicotineZ
Jan 31, 2006 04:16 AM
Tatanko
Dec 25, 2004 08:56 PM
nick_ouellette
V6 Tech
Jun 24, 2003 10:37 PM
