Drive shaft help
Old Dec 26, 2003 | 07:50 PM
1984camaroz28's Avatar
Drive shaft help
I found a driveshaft that i need it has the right transmission yoke but the rear is for a 9in ford.... i have a 10 bolt for now will it work ? is it no good ? or can i change it.
Old Dec 26, 2003 | 07:53 PM
You should post driveshaft questions on the "Drivetrain" board.
Your stock 10-bolt probably has a 1310 series u-joint. A "9-inch" may be a 1350 joint. You need to verify both numbers, and get the part # for a "cross-over" u-joint that will fit the pinion yoke and the DS yoke.
Old Dec 26, 2003 | 07:55 PM
its a bone stock rear... i will find what the drive shaft is
ch3vyb1gbl0ck
Classic Engine Tech
Oct 23, 2023 08:07 PM
Cam's maro
Dec 28, 2014 09:30 AM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
Victory Racing
Sep 1, 2002 06:05 PM
