Drain coolant for tb bypass?
Old Jun 19, 2004 | 11:49 AM
Terran2k's Avatar
Do I drain the coolant to do the tb coolant bypass? I seen the question asked b4 but no answer. I would think I would need to drain some, but maybe i wont.
Old Jun 19, 2004 | 12:26 PM
1msfyter's Avatar
When you pull the front hose a small trickle will come out , not much at all. Stuff a bunch of towels under the TB and near the opti. You'll see its very little.
Old Jun 19, 2004 | 09:10 PM
Terran2k's Avatar
oh man, what a pain in the butt, I was tryin to do it with the alt still in place, but its impossible i tell you! there's not enough rooms for my hands to move around, I'll remove the alt tomorrow and do it.
Old Jun 20, 2004 | 03:54 AM
dabez1's Avatar
just put a small towel under the hoses, I ended up cutting one of the hoses and connecting it the teh hose on the right side of the TB, The otehr hose was a bitch to take off.
Old Jun 20, 2004 | 07:51 AM
zeemadman's Avatar
They recommended way to do it is to unbolt the TB, then remove the lines...
Old Jun 20, 2004 | 09:40 AM
ibanez6rg's Avatar
I've never had coolant come out on me the times that I have done the bypass.
Old Jun 20, 2004 | 12:14 PM
Terran2k's Avatar
Hey guys thanks for all of your help. I just finished it right now. today everything went into place easily, guess i was frustrated last night with that 90 degree hose piece, it just didnt want to budge, ended up cutting it at the bend and removing the two halves.
Formula Steve
Sep 19, 2023 08:31 AM
68camaroboltz
Oct 5, 2015 01:46 PM
colts0455
Oct 4, 2015 09:47 PM
football4life
Oct 4, 2015 07:48 AM
Rod Bender
25
Sep 16, 2015 01:47 PM
