Does Your LT1 Run Worse When Fans Kick Turn On?
Old Sep 11, 2009 | 11:24 AM
WestCoast96Z28's Avatar
In really hot days out here in California, my engine is just not happy. 90 deg plus outside, and it just hesitates...just slightly, but annoying enough.
And when the fans kick in (high), the engine just feels drained. The voltage gauge seems to dip a bit..not into red, and overall engine just seems to struggle. It's never died on me because of this (knock on wood), but feels like it.
Does your car feel drained with the radiator high fans turn on? Do I have an electrical issue...weak alternator or something?
Old Sep 11, 2009 | 11:51 AM
Z28SORR's Avatar
No! Can't even tell when they come on. Other then the temps. stop going up.
Old Sep 11, 2009 | 01:42 PM
KYWes's Avatar
Is your car throwing any codes? The fans come on when a fault code occurs.
I thought for the longest time that I had an error in my PCM program because the fans would come on unexpectedly. Turns out I had a bad IAT throwing the code causing the computer to activate the fans.
You didn't mention seeing a service light so I'll assume not, but thought I'd put the idea out there.
Old Sep 13, 2009 | 07:21 AM
OneShoe50's Avatar
Sounds like your fans are drawing high amps, check connections for corrosion and check wiring for any damage, and check alternator output. The age of the fans can also affect amp draw.
Rich_z28
Sep 13, 2002 03:35 PM
Rich_z28
Sep 8, 2002 12:00 AM
Rich_z28
Aug 29, 2002 11:01 PM
Rich_z28
Aug 29, 2002 10:44 PM
Rich_z28
Aug 27, 2002 12:20 AM
