does vats control the starter?
Old Nov 15, 2008 | 04:48 PM
vscott71's Avatar
My car wont start. It was running and I noticed my volt meter was dead. I thought maybe the gauge was out. Shut the car off and now it won't crank at all. NO click, no nothing and the volt gauge is still dead. I tried to get Walmart to duplicate my key this morning,but it wouldnt fit it their machine. I wonder if they damaged the pellet in the key trying to put it in the machine. I check the wire to the alternator and it is good. What do the volt gauge and the starter have in common so I know where to start looking? Everything else works fine -radio, windows, etc...
Old Nov 15, 2008 | 04:54 PM
LaredoZ28's Avatar
Sounds like ur alternator went out and drained ur battery. A friend of mine had vats problems and his car wouldnt do anything. no click or anything.
Old Nov 15, 2008 | 05:14 PM
vscott71's Avatar
just put a new battery in it - still nothing.
Old Nov 15, 2008 | 06:29 PM
VATS will keep it from cranking, but won't affect the volt gauge. A security light would indicate a VATS problem.
Old Nov 15, 2008 | 06:46 PM
EviLZ28's Avatar
Sounds like a fuseable link may have burned up. Have you checked the starter wiring?
Old Nov 17, 2008 | 05:21 PM
vscott71's Avatar
FIXED! It was a blown fuse that goes to the gauges. I replaced the fuse and it starts right up!
Old Nov 17, 2008 | 06:16 PM
LaredoZ28's Avatar
thats good to hear. glad u got it back up and running.
Maroz28maro
Jul 29, 2016 07:45 PM
Knightscrapper
Feb 4, 2016 10:25 AM
surreybrad
Jul 5, 2015 10:36 PM
Klypto
Mar 9, 2015 04:25 PM
