Does the starter on my car stay engaged??
Old Nov 10, 2003 | 11:26 AM
S.J.S.'s Avatar
I was just curious because I put my motor back together and cranked it. I was pre-oiling the motor and it sounded weird, that was because I had the plugs out it was just winding. I took off the converter cover and saw the starter engaged. It stays that way???
Old Nov 10, 2003 | 12:57 PM
No. The starter gear should retract from the ring gear. Sounds like it is binding. Did you check tooth clearance and shim correctly?
Moving to LT1 Tech.
A's 91 Z28
Dec 7, 2014 12:09 PM
tds1213
Nov 27, 2014 12:55 PM
Dyoung_Z28
Nov 25, 2014 05:26 PM
Lt1son
N2O Tech
Nov 25, 2014 01:52 PM
USAirman93
Nov 24, 2014 03:37 PM
