Does this Replace the Balancer Pulley?
Old Feb 13, 2005 | 09:09 PM
c0rey's Avatar
I was looking on a website and I found this pulley Im not familar with underdrive pulleys, so I figured I would ask on here. Here is all the info that it gives me.
BBK Performance 1591
LT-1 UNDERDRIVE PULLEY
Or I also found this one.
March Power & Amp Series Underdrive Crank Pulley w/ Overdrive Alternator Pulley, 1993-1997 LT1 F-body, 1994-1996 Impala SS
My stock balancer pulley got bent, so Im looking for something to replace it.
Old Feb 13, 2005 | 09:19 PM
OBE1 95Z28's Avatar
Re: Does this Replace the Balancer Pulley?
I see from your signature that you're running an ATI blower. Not sure with that system, but my Vortech blower crank pulley uses a modified stock crank pulley (face ground down to accept the blower pulley). Might want to check with ATI about crank pulley requirements.
Old Feb 13, 2005 | 09:25 PM
c0rey's Avatar
ATI uses the stock pulley with a spacer. No modifications are needed to the pulley.
Old Feb 14, 2005 | 10:31 AM
1-bad-z28's Avatar
the stock pulley is also the balancer. I had to bolt my under drive pulley between my balancer and hub
Old Feb 14, 2005 | 10:39 AM
FryedClutch's Avatar
no those dont replace the balancer but there is an underdrive balancer out there just do a search for them but they are a bit pricey
Old Feb 14, 2005 | 11:36 AM
ASP makes an integrated damper/UDpulley that fully replaces the stock damper/pulley.
http://www.aspracing.com/frame.htm
Just curious.... why would you put a U/D pulley on a blower car? It would seem the HP gain is miniscule.
Old Feb 14, 2005 | 02:48 PM
c0rey's Avatar
Im just gettin the stock balancer mine is bent and makes the blower pulley wobble something feirce.
HectorM52
Jul 30, 2017 11:46 AM
REDNECKISBOSS
Mar 22, 2015 08:31 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
cyteone
Feb 7, 2015 06:04 PM
