Does EGR removal force the use of higher octane gas?
Old Nov 17, 2007 | 03:38 PM
  #16
Unless you monitor knock retard, you don't know if you have "problems", meaning loss of performance. Tuning it for 87 makes sense if that's what you want to run, as long as you recognize you have given up that performance.
Old Nov 17, 2007 | 05:55 PM
  #17
drptop70ss's Avatar
I dont want to tune it for less performance, I would run a lesser engine if I wanted to do that, but I appreciate the info. I just want to run a stock LT1 M6 with the EGR and AIR pump removed. Should I get the EGR programmed out or will leaving the EGR solenoid plugged in keep a code from being thrown? I have read that removing the AIR pump wont throw a code.
Old Nov 17, 2007 | 06:32 PM
  #18
DrewHMS97SS's Avatar
Originally Posted by drptop70ss
LOL I am not calling anyone a moron, and my car runs fine on 87. Will I run 87 in a 10:1 454 with iron heads? No, but it works fine in my LT1. Since nobody else runs 87 I guess the question doesnt apply here, I will just block the EGR and see how it runs on 89 first.
I felt substantial difference in the cars throttle response in Denver with 87. I would never run anything less than 91 on an LT1. Getting by with more knock retard is not the way to go. 2$ per fill up is worth peace of mind and better performance.
Old Nov 17, 2007 | 07:40 PM
  #19
pizzi-man's Avatar
How much performance are we talking about? I've rum premium and regular with not much differance except in the pocket book. Here in San Francisco we have some of the highest prices in the nation. Let us also note that there are all kinds of levels of performance. My LT may not be as fast as it could be but then again it's way better than the 327 it replaced.
Old Nov 18, 2007 | 01:54 PM
  #20
LiENUS's Avatar
Get the EGR programmed out, the computer adds a couple degrees of timing when the EGR is on.
Old Nov 20, 2007 | 08:19 PM
  #21
Dave89IROC's Avatar
you won't run 87 in a iron head motor at 10:1, but you will in an aluminum headed motor running 10.5:1???
Old Nov 20, 2007 | 08:26 PM
  #22
drptop70ss's Avatar
A reverse cooled aluminum headed engine? Absolutely. Iron heads retain much more heat then aluminum heads, plus the reverse cooling helps keep the heads cooler and more evenly cooled helping stop hot spots. If my 454 runs into detonation there is no computer to back off the timing either.
97SSdude
Dec 31, 2014 07:43 PM
simple
Aug 11, 2002 11:56 AM
TrouserSnake
Aug 8, 2002 06:17 PM
TrouserSnake
Aug 7, 2002 12:43 PM
DarkHorse
Aug 3, 2002 10:17 PM
