Does anyone elses heat suck??
Old Dec 8, 2002 | 11:59 PM
  #16
drop top steve's Avatar
Originally posted by LT1Thunder
I guess i'll have to try to flush it out and just see what happens. I just hope it works cause it's getting pretty damn cold outside.
Flush the heater core and check the flow valve, it's between the 3/4 metal pipe and WP, black plasti, about two inches long.
Old Dec 9, 2002 | 12:58 AM
  #17
TobyZ28's Avatar
Well My heater works great, Heats up VERY WELL when the engine is warm. I drive top down out here in Vancouver in the middle of the winter with the heat blasting, comfy in the city, doable for short highway runs too=)
Old Dec 9, 2002 | 03:22 AM
  #18
Hybrid86Z's Avatar
could someone explain in good detail what all is involved in flushing out the heater core?? where the hoses are (passenger side of engine comp???).....
thanks, I'm thinking this is what i'm going to do, since my heater doesn't work well, even at good engine temps. AC works great.....but not much heat.
btw, i run a 180* thermo w/ hypertech fan switch mod...
Old Dec 9, 2002 | 09:27 AM
  #19
Coolformula's Avatar
Smile
Yea I have teh 160 stat, and my heater don't work. I think I'm going to try to flush my heater coil out. Thanks for this post.
Old Dec 9, 2002 | 06:34 PM
  #20
RENE95Z's Avatar
Here you go
http://web.camaross.com/forums/showt...threadid=49305
Old Dec 9, 2002 | 06:46 PM
  #21
pearlpurple's Avatar
160 thermo and I get decent heat, not blasting melt your face or antything but if I am driving for about 5 - 10 minutes (25 - 30 degrees outside)good heat, I eventually have to turn it down to keep it comfy.
Who ever is going to flush their heater core, remember the otpi and remeber to bleed air.
Old Dec 12, 2002 | 07:47 PM
  #22
BennyBoy's Avatar
Here is the procedure, with pictures:
http://www.vifbody.ca/articles/displayarticle.php?id=4
Old Dec 12, 2002 | 11:20 PM
  #23
D James's Avatar
with my 160 thremo and fans programmed at 170 I was getting no heat, it was barely warm on the lowest setting, I was freezing the entire one hour drive everyday. I went through and flushed the core and filled up on coolant(I was low) and ever since I have heat like crazy, with it on low it gets to hot where I have to turn it off, and I have a convertible, this is in 8-15 degree weather, so you should flush and really go over your system.
Old Dec 13, 2002 | 12:20 AM
  #24
br1ev8's Avatar
yeah my heat sucks, but its not because the air blowing out isnt hot. its because the retard that owned my truck before me installed an aftermarket radio without using a dash kit that is needed to pull the deck away from the ac/heat ducting behind the radio. so the way he made it fit was to cut a hole in it so that the radio fit halfway in the ducting. so now every time i turn on the heat, the air just blows right into the back of the radio i installed, instead of out of the vents like it should
of course this is in my truck and not an f body
Old Dec 22, 2003 | 02:12 PM
  #25
Installed a new 180,flushed heater core, I can hear the heater door opening and closing. But my heater sucks, last winter I had 0 hear, any ideas thanks
Old Dec 22, 2003 | 02:50 PM
  #26
gritter's Avatar
so flushing the heater core is basically the same damn thing as a coolent flush?
Countryboychevy
Jun 13, 2015 02:49 PM
FredM
Jun 5, 2015 05:45 AM
NewsBot
May 10, 2015 08:10 AM
jasonduaine
Mar 7, 2015 09:44 AM
Jan 23, 2015 01:13 PM
