Do you have to have a good opti to run LTCC?
Old Feb 10, 2006 | 01:42 PM
Sleeper_Z's Avatar
I was thinking about doing the LTCC conversion but I was unsure if you have to have a good opti to start with. If anyone could help me out it would be greatly appriciated. Thanks
Jeremy
Old Feb 10, 2006 | 01:46 PM
djw's Avatar
djw
Re: Do you have to have a good opti to run LTCC?
The optical cam sensor in the opti still needs to be good, since that is what the pcm uses to calculate when to fire a particular cylinder.
Old Feb 10, 2006 | 02:09 PM
Sleeper_Z's Avatar
Ahh thats what I was thinking but wasnt 100% sure. The optical sensor is what actually goes bad in an opti isnt it?
Jeremy
Old Feb 10, 2006 | 02:15 PM
Javier97Z28's Avatar
Moderator
Jeremy
Not always.. my cap/rotor self destructed in my opti
Old Feb 10, 2006 | 02:40 PM
madwolf's Avatar
Yes. Many times oil/dirt will get inside, or simply oxydation which may lead to your opti's failure in the first place. If the sensor has been compromised, the LTCC won't help.
Old Feb 10, 2006 | 04:09 PM
Sleeper_Z's Avatar
Well shoot. I guess I might look into trying out the new MSD opti. Ill give my friend the seach function a little bit of my time and see what I come up with. Thanks a ton guys.
Jeremy
Old Feb 10, 2006 | 04:53 PM
djw's Avatar
djw
Like Javier said it isn't 100% that it is the sensor. The problem maybe just with the cap and rotor. shoebox has some good stuff on his site for test if the opti is giving the correct information to the pcm.
http://shbox.com/1/4th_gen_tech2.html#opti_test
The test connector for the opti is the 4 wire connector mounted by the evap along the passenger side of the intake manifold. I would run shoeboxe's test on the opti before you give up hope on it.
Old Mar 21, 2006 | 02:33 PM
2QUIK6's Avatar
Actually from what I have read the cap and rotor are most likely the failure points instead of the optical sensors. If the opti part is in fact bad, you may be able to pick up a used one real cheap.
Old Mar 21, 2006 | 02:37 PM
dreamer1q's Avatar
Just do what I did, buy a brand new Opti, open it up, and cut off the rotor Nothing like killing a brand new part.....it was fun
Old Mar 21, 2006 | 03:23 PM
WS Sick's Avatar
You can get the Lower part of the opti from O'Reillys for less than 200$
mikey4play
Mar 15, 2015 11:45 AM
97TA-WS6-Con
Feb 1, 2015 01:01 PM
blue89iroc
Jul 18, 2002 04:41 PM
