Do most people take out, or add timing when tuning your car OBD1
Old Aug 13, 2003 | 08:15 AM
ONELOUDKAR's Avatar
the header says it all....
Old Aug 13, 2003 | 11:33 PM
Dan K's Avatar
Idle? Part throttle? WOT?
This really should be in the computer/diagnostics forum, it'll get lost in here.
Old Aug 13, 2003 | 11:46 PM
96speed's Avatar
Re: Do most people take out, or add timing when tuning your car OBD1
All of the above plus leave it alone .
Ryan
Old Aug 14, 2003 | 12:06 AM
turbo_Z's Avatar
mine had more timing low rpm low KPA and less timing at WOT... everything else is untouched.
Old Aug 14, 2003 | 01:01 AM
BPS's Avatar
BPS
added timing and idle speed at idle, left the mid range alone, decreased timing in the upper rpm/map range
Old Aug 14, 2003 | 08:11 AM
ONELOUDKAR's Avatar
What would be the reason to add timing and idle speed at idle?
Curious to see if I need to add timing at idle...... car drops rpm's to like 500-600 and throws 2 codes, SES light comes on.
Old Aug 14, 2003 | 10:50 AM
BPS's Avatar
BPS
installed new cam, found that the revs bounced a lot at stock idle and the car bogged/stalled on takeoff and reverse from timre ti time.
So I upped my idle by a couple of hundred to smooth it out and if you increase idle you need to add some timing
Looking over other peoples files this seems like a typical adjustment that's made to accomidate aftermarket cams.
Queens94z28
Dec 20, 2014 09:11 PM
cmdeshon
Dec 12, 2014 10:51 PM
USAirman93
Nov 24, 2014 03:37 PM
JasonD
Jul 15, 2002 02:17 PM
Brent94Z
Mar 21, 2002 04:44 PM
