Do I plug this hole?
I'm in the process of putting my motor back together and I've basically connected everything and reinstalled everything....but there is a threaded hole above the aux oil pressure sensor hole that I don't remember unbolting anything from.
http://www.shbox.com/1/aux_oil_port.jpg
it's the upper hole shown the picture on shoebox's website. Do I just plug this?
also are there any other holes in the block and head that I need to plug? This is the first time I've attempted a rebuild.
thanks!
thanks!
The lower hole is where the 93's had the OP sensor. The engine mounts are quite a bit farther forward than that position.
I don't have a block lying around anymore so I can't just go look. If it's threaded, put a plug in it...it won't hurt anything.
Victor Lamb
Aug 26, 2017 02:52 PM
eanhl2004
Apr 4, 2015 12:01 PM
