Do I plug this hole?
Old May 10, 2009 | 12:02 AM
Violat0rX's Avatar
I'm in the process of putting my motor back together and I've basically connected everything and reinstalled everything....but there is a threaded hole above the aux oil pressure sensor hole that I don't remember unbolting anything from.
http://www.shbox.com/1/aux_oil_port.jpg
it's the upper hole shown the picture on shoebox's website. Do I just plug this?
also are there any other holes in the block and head that I need to plug? This is the first time I've attempted a rebuild.
thanks!
Old May 10, 2009 | 02:52 AM
monster81's Avatar
its a threaded hole!,,,where does that hole go,,,itsnt this where the engine mounts fit ?!!!
Old May 10, 2009 | 03:46 AM
SS44Camaro's Avatar
depends on what year your car is. thats where my oil sensor goes on my 94 i think. the newer ones are on the back of the intake
Old May 10, 2009 | 08:06 AM
bw_hunter's Avatar
The lower hole is where the 93's had the OP sensor. The engine mounts are quite a bit farther forward than that position.
I don't have a block lying around anymore so I can't just go look. If it's threaded, put a plug in it...it won't hurt anything.
Old May 10, 2009 | 08:48 AM
Nothing goes in the hole. It is an old casting hole that used to be used for manual clutch linkage mounting.
Old May 10, 2009 | 10:43 AM
Violat0rX's Avatar
great! thanks guys. I'll just go buy a something to plug it up.
Old May 10, 2009 | 11:19 AM
Venomous360's Avatar
You dont have to plug it as shoe said, nothing goes there, not even a plug.
I dont have one there and nothing spills out of it so your good the way it is.
Old May 10, 2009 | 01:10 PM
No plug needed. It's a blind hole.
Old May 12, 2009 | 02:52 PM
Violat0rX's Avatar
nice! even better.
Victor Lamb
Aug 26, 2017 02:52 PM
alex5366
Jun 8, 2015 07:52 PM
geinsteder
May 6, 2015 06:02 AM
eanhl2004
Apr 4, 2015 12:01 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
