Difficulty of changing coil?
Old Mar 4, 2004 | 12:09 PM
black bandit's Avatar
Hi fellows-as the title, I was curious how hard it is swap the old for a new. I heard that drilling is required. Is this necessary? Any advice for a novice mechanic?
Old Mar 4, 2004 | 12:11 PM
Type_O_Negative_1320's Avatar
It's easy to do. You don't have to drill the rivets out...I wrapped my old coil up in a towel, stepped on it to stabilize it (I'm too cheap to buy a vice), and knocked the heads of the rivets off with a chisel. Quick and easy.
Old Mar 4, 2004 | 12:30 PM
AsianSensation's Avatar
Easy ++. I used a Dremel to take the rivets off. Of course your's will be a dual connector (ie MSD 8226) rather than a single connector coil.
http://www.97ta.com/msd_ignition_coil.shtml
Old Mar 4, 2004 | 12:32 PM
Compstall's Avatar
Or you can use a dremel tool and cutting wheel to knock off the heads of the rivets.
Old Mar 4, 2004 | 12:40 PM
ibanez6rg's Avatar
I grinded the rivets and then hammered them out.
Old Mar 4, 2004 | 02:17 PM
LT1 Bunny's Avatar
ditto
PCLZ28
Dec 24, 2015 05:19 PM
grabbem88
Mar 18, 2015 01:25 PM
captcorvette
Mar 7, 2015 12:37 PM
grgguy
17
Feb 23, 2015 07:57 PM
maybe2fast
Feb 5, 2015 05:14 AM
