Differences in Exhaust Manifolds
Ok guys, I've been reading the archives and I'm trying to figure out exactly what the differences are in the early vs late and f-body vs b-body manifolds. I need a pass side one for a project on my corvette and I'm trying to figure out exactly which one I should be looking for. So what are the differences.
I know the egr hook ups are different on early vs late. Also the single vs dual cat setup changed the length of the drivers header(not the pass too?). Are there any other differences?
And I read somewhere there is an angle difference of some sort on the f-body vs b-body but it was never explained. If someone knows please speak up.
Thanks guys.
Thanks guys.
Re: Differences in Exhaust Manifolds
You've got it covered….the late f-body has a different driver side manifold flange because it connects directly to the cat.
The b-body manifolds have extensions past the flange that goes inside the pipes, the f-body flanges are flat.
"The b-body manifolds have extensions past the flange that goes inside the pipes, the f-body flanges are flat."
So the connector on the F-body is flat and the b-body has those flared cup connectors? That is very good to know thanks.
Chris Anderson
Jan 27, 2015 08:30 AM
