AIR! delete
Old Sep 7, 2004 | 11:01 AM
"White Knight"'s Avatar
AIR! delete
What all do you need to delete the air pump? Do you need any block-off plates or anything or does the pump just come off and you plug the hoses? Any info would be helpful. How much does it weight?
Old Sep 7, 2004 | 11:13 AM
sssalah's Avatar
Re: AIR! delete
It is not heavy may 2-3 lbs, you can remove it and plug the opening on the intake ducting. You can remove the tube for a cleaner look and plug the holes at the manifold or it may be easier to plug the holes on the tube.
Old Sep 7, 2004 | 11:44 AM
Re: AIR! delete
I remember hearing something about 22mm plugs for on the manifolds. not sure what type of plugs they are talking about.
DirtyDaveW
Dec 1, 2016 05:37 PM
HarleyZ28
Oct 5, 2015 06:23 AM
armedtrigger
Feb 24, 2015 08:30 PM
95chwagon
Jan 13, 2015 09:19 PM
cmdeshon
Dec 27, 2014 10:06 AM
